spark plug gap too small? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 03-24-2005, 11:16 PM   #1 (permalink)
Electrical Whiz
Drives: Topless!
3000SL95 is an unknown quantity at this point
Feedback Score: 39 reviews
Default spark plug gap too small?
So i changed my spark plugs on the vr4 the other day, i had some old crappy plugs in the rear and some relatively new denso iridiums ik20's in the front. i replaced all 6 plugs with denso iridium ik24's and replaced the wires with ngk wires. The new iridiums said they were gapped at .032, but when i tested them with my gap gauge i found they were gapped more around .027 or so. i went ahead and put them in ayway, thinkin maybe my gap gauge was off since it was kinda old and rusty. Well the car now runs smoother than before, but doesn't feel as powerful, it feels like i start to lose power around 3500-4k rpm's. Would having too small of a plug gap cause this problem?
1995 Vr4 Spyder purchased 3/01/05 Completely Stock. currently pushing 357 AWHP
3000SL95 is offline   Reply With Quote Quick reply to this message
Old 03-24-2005, 11:21 PM   #2 (permalink)
Crank up the boost!
TuRbO3K's Avatar
Drives: 93 VR
TuRbO3K is an unknown quantity at this point
Feedback Score: 11 reviews
Default Re: spark plug gap too small?
ummmm yea its too small.
93 VR4 BPU
12.89 @ 107.80 - 1.83 60'
06 600RR
TuRbO3K is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 12:37 AM   #3 (permalink)
Evolved Member
GreenMonsterVR4's Avatar
Drives: 2006 EVO MR
GreenMonsterVR4 is an unknown quantity at this point
Feedback Score: 5 reviews
I have actually been told to make my gap smaller so it can handle higher boost. I have mine at .034 and I am told they should be around .028, so you should be fine.
SOLD! '95 VR-4
SOLD! '99 3000GT SL
Current car- '08 EVO GSR
Mods- AMS intake - AMS DP - Tsudo DP-back exhaust - GrimSpeed 3-port - Kaizen Tune @ 26psi - Short throw - Synapse Synchronic BOV
Latest addition- '99 3000GT SL, RED
GreenMonsterVR4 is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 01:09 AM   #4 (permalink)
user and abuser...
bengeeee's Avatar
Drives: 95 Stealth TT
bengeeee is an unknown quantity at this point
Feedback Score: 8 reviews
actually too small of a gap can lead to power loss. Your arc may not be wide enough. In otherwords you probably arent igniting the entire fuel mixture up top. NEVER EVER TRUST THE GAP OUT OF THE BOX. They are almost always wrong. Use your feeler guage or gapper. You just need to find the medium that works for you. Try around 32 and see what happens.
Ben
92 Sandstone VR4 (Sold),94 Pearl Yellow RT TT (Sold)
94 Red 3000gt VR4 (Sold), 2007 Trailblazer SS (DD)
bengeeee is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 08:21 AM   #5 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Mellon is an unknown quantity at this point
Feedback Score: 18 reviews
I'm gapped at .022 on NGK coppers... the car is far from slow
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 09:10 AM   #6 (permalink)
Trevor's Avatar
Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4Trevor Level 4
Feedback Score: 22 reviews
0.027-0.028 isn't too tight for a street car. Personally I would do some work to impove the ignition system if I had to go any tighter than that though.
11 Cadillac CTS-V Coupe
Trevor is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 09:13 AM   #7 (permalink)
vr4dave
Vr4twinturbo92's Avatar
Drives: 3SI MYTH BUSTER
Vr4twinturbo92 is an unknown quantity at this point
i gap at 28 and even with nos i get no blow out ,,,but i do have the hks dli
92 VR4 TwinTurbo 15G TURBOS
DN hard pipe kit ZEX nitrous w/ purge kit
mashi 18x8.5frt 18x9.5 rear on hankooks
245/40s frt 275/35s rear polished intake and valve cover Anidized covers pte 680cc injectors
emange and profec eo1 with stock mass
Greddy profec b boost controller
greddy remote switching system
rps 6 puck and rps lightened flywheel
Custom interiorHKS turbo timer
Pioneer and custom speaker set up
Dual pod gauges,a/f and boostSupra fuel pump
HKS TWIN POWER DLI DEJON TOOL FMIC
Vr4twinturbo92 is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 10:11 AM   #8 (permalink)
Mellon's Avatar
explain to me the benefit of a .030 gap over a .022 gap? I mean really... is that going to get you any more horsepower or a more complete burn? 8 thousandths?
Old 03-25-2005, 10:39 AM   #9 (permalink)
Trevor's Avatar
A larger gap will allow a more complete burn and therefore less emissions under low load conditions (idle and cruise). You can also run a leaner mixture in those areas without running into a misfire condition.
Of course once the load goes up and cylinder pressures increase it doesn't take much of a spark to get the burn going and things are so tight molecularly that the burn is more apt to complete without missing any fuel.
Old 03-25-2005, 11:10 AM   #10 (permalink)
vr4dave
yea it is far from slow chris ,,,its verrrrrrry sloooooooowwwwww
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
