Old 06-10-2008, 07:46 PM   #11 (permalink)
SOHC you in the FACE
Ondontii's Avatar
Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6Ondontii level 6
Default Re: Single T04e Vr4
Good idea to go with the big wastegate because that location/angle is not friendly for wastegate flow.
Brent
1992 Duster -12.7@114 - 14psi boost -13.9@107.4 - 5psi - 6g72 3.13L "built" SOHC, Precision T67 P-trim, Tial 38mm open dump, 3" downpipe, 20x12x3" evo style intercooler, 7:1 compression, balanced, shot peened rods, heavily ported heads (+40% on flowbench), Ferrea Competition Plus +2 +1 stainless valves, Nielson Vintage 278 duration custom turbo cams, RPW Cam gears, Custom Ram Style short runner intake manifold, Walbro 255hp, 6*47# injectors, +0.096" Forged Venolias, Total Seal chrome gapless top rings, Fidandza Flywheel, Clutchnet 3 puck solid hub, OBX Helical LSD, Zeitronix wideband/EGT/Boost sensors, 100watt DevilsOwn Meth Kit.
1994 Spirit - 13.987@101.89 - 5psi- 6g72 SOHC, K27 Turbo
Ondontii is offline   Reply With Quote
Old 06-10-2008, 08:53 PM   #12 (permalink)
Been here since 01!
HenesseygtoMR's Avatar
Drives: 100 yds downfield
HenesseygtoMR Level 1HenesseygtoMR Level 1
Stock shortblock? heads/cams?
what size turbo?
Soarer Turbonetics T66.
HenesseygtoMR is offline   Reply With Quote
Old 06-10-2008, 09:04 PM   #13 (permalink)
Paid Member
outkastvr4's Avatar
Drives: 92 vr-4, 87 yota
Trader Rating: (7)
outkastvr4 is an unknown quantity at this point
actually the wastegate is ported at the center of the collecter so looking from the inside of the manifold is has pretty good flow.
the turbo is a garret t04e with 70a/r over 83a/r on a stock block, im rebuilding a block cuz mine has blown rings or bad guide seals so i might work the heads a little minor port n polish and cams if money permits. can anybody get there hands on some worked heads or cams?
1992 3000GT VR-4- CUSTOM to4e single turbo kit, full 3in exhaust with 2 1/2 outlets, ported intake,550s,safc2,GM MAFT,4in FMIC, and much more to be bought
1987 Toyota turbo pickup-SOLD
1995 Nissan 240sx-bone stock project car
outkastvr4 is offline   Reply With Quote
Old 06-10-2008, 09:09 PM   #14 (permalink)
Been here since 01!
Good deal. You get on it yet?
PS might wanna edit your sig
Old 06-10-2008, 09:13 PM   #15 (permalink)
Paid Member
outkastvr4's Avatar
Trader Rating: (7)
not yet im waiting for to get a fresh motor inside it and get a tune on it
Old 09-07-2008, 05:43 AM   #16 (permalink)
2 of 3 in the US!
ES 3000TT's Avatar
Drives: ES 3000TT
Trader Rating: (25)
ES 3000TT is an unknown quantity at this point
so how did this turn out to date?
ES 3000TT
Soon something else!!
2 of 3 in the US!
ES 3000TT is offline   Reply With Quote
