#11 (permalink) | |
Here for the tuna.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts ![]() |
#12 (permalink) | |
I'll using my stock FPR. I'm gonna have the shop install the fuel pump and I will get them to hot wire it. I would install this myself but everything is so rusted up, I'm gonna have them replace the high pressure fuel line which connects to the assembly. I didn't think about changing my fuel filter, is this a big concern?
Manj's Wanna-Be GTO
Complete Custom Body Kit and Paint (Viper Red with 3 pearls), 19T-HL with 7* clip, FMIC, Greddy BOV , eManage Blue, Denso 660's, 18" Kosie Sniper Rims, HKS Intake, 3" Downpipe, Testpipe and MagnaFlow Exhaust system, ACT Clutch, Eibach Springs, NGK Plugs and Wires, Autometer boost and Air/Fuel gauges, Supra Fuel Pump, EGR Block Off Plates, Pioneer Deck, 3 Boswick Amps, 2 12" Boswick Subs, JL Front and Mids...... Can't forget the Bat Man floor mats ![]() ![]() |
#13 (permalink) |
Here for the tuna.
The fuel filter would just be a general maintainance issue, if you think it's fine then don't worry about it. But it's just something I would personally do because I'm weird like that.
![]() Watch out for that rust by your fuel pump assembly. If they snap off one too many studs, or torque your hard line a little too much, you will have a fuel leak and it will suck. Just a word of warning. Building a S/S line fuel pump assy with AN fittings might be a good idea too. |
