SAFC II Tuning Help. - Page 3 - 3000GT/Stealth International Message Center
Old 02-25-2013, 09:39 AM   #21 (permalink)
Always Learning
mikeyVR4's Avatar
Drives: 2013 WRX Prem 4D WRB
mikeyVR4 is an unknown quantity at this point
Feedback Score: 8 reviews
Default Re: SAFC II Tuning Help.
Originally Posted by beasting View Post
the o2 looks fine to me, it seems you must have a big vacuum leak..
a datalogger would tell you more...
I am trying to get my brother-inlaws scanner but of course its pulling teeth to get him to help me or let me borrow anything.
I think I will just buy the HHH logger but I know Ray P. told me a logger isnt needed, besides logging knock, because scanner does the same thing.
mikeyVR4 is offline   Reply With Quote
Old 02-25-2013, 10:00 AM   #22 (permalink)
Aww just a base..
DigiiManDan3KGT's Avatar
Drives: 95 awd tt, 99 Base
DigiiManDan3KGT is an unknown quantity at this point
Feedback Score: 10 reviews
His 02's arent cycling at all. Get the THROTTLE POINTS- LOW set back to 25 and the HI back to 50. I can see you were confused but the THROT POINT LOW / HIGH needs to be set correctly. Msg back if your still having that problem with this fix.
The fuel point corrections (RPM NE POINTS) leave those at zero. You dont need negative or positive numbers yet.
Green 1995 3000GT // 15t Turbos // ATX to MTX // NA to TT // FWD to AWD // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
DigiiManDan3KGT is offline   Reply With Quote
Old 02-25-2013, 10:35 AM   #23 (permalink)
Always Learning
mikeyVR4's Avatar
Okay I will do exactly as you noted. I am working but at home currently. I will switch to 25% low - 50% high.
I will also check out those NE points and let you know.
Thanks!
Old 02-25-2013, 12:09 PM   #24 (permalink)
VR3.9's Avatar
Drives: 93 VR4 & 91 VR4
VR3.9 Level 1VR3.9 Level 1VR3.9 Level 1
Feedback Score: 25 reviews
Originally Posted by mikeyVR4 View Post
Hey guys,
SettingMenu
1.) Hi-Thrtl : 800rpm 0%
2.) Lo-Thrtl : 800rpm +50%
EW VIDEO[/SIZE].[/B]
IMG_0482.MOV - 3si.org - YouTube
notice 2. Lo-Thrtl : 800rpm +50% this should be 0%
at 38 seconds in the video you see 7200rpm set to zero. hit the left arrow key and it will go through all the rpm set points. make sure they are all 0. then do the same for the high throttle points.
The SAFC has rpm correction points for high throttle( when the throttle is 50% or more (if you set hight throttle point at 50%)
It has low throttle correction points for when it is less than 20% open (if your low throttle point is set to 20%)
Make sure all rpm points are set to 0%.
Most powerful 13T car on the planet @501awhp, PTE 780CC injectors, AFPR, E85, Greddy Profec B, 3.5" Granatelli MAF, MAFT, Apexi ITC, SS Headers and O2 housings, 3SX downpipe, CRX racing FMIC, Dejon intake pipes, Ground Controls, Maximal adjustable rear control arms, Maximal TC Brace, Poly front and rear mounts, Vacuum Reduction, EGR block off plate, Hot Wired Walbro 255 and inline Walbro 255, Southbend stage 3 clutch, Slotted and vented rotors, SAFCII, Turbo XS BOV, 3SX FP hotwire, Seatle Short Shifter, Jackhammer timing gears: Best 1/4 mile 12.33 at 114.9 mph 1.79 60ft.
VR3.9 is offline   Reply With Quote
Old 02-25-2013, 12:19 PM   #25 (permalink)
Always Learning
mikeyVR4's Avatar
Okay cool will definitely do that during my lunch break and report back.
Thanks man I really appreciate it! You have no idea.
Old 02-25-2013, 02:56 PM   #26 (permalink)
Always Learning
mikeyVR4's Avatar
New video.
MVI 2565 - YouTube
So I tried to put all NE points on zero but you cant adjust the RPM points any lower.
All RPM points are at 0%
Ex:
Ne1: 800 (lowest)
Ne2: 1200 (lowest)
ne3: 1600 (lowest)
etc.
Old 02-25-2013, 03:12 PM   #27 (permalink)
VR3.9's Avatar
Yep the SAFC looks right for 360 injectors. If you still have the stock maf I would put it on to see if the problem goes away. If it doesn't then I would double check how you have the SAFC wired in and possible take it back out.
Doing one upgrade at at time makes trouble shoting much easier.
If it does make the problem go away then it could be you have the wrong MAFT instructions. There is a pdf which is for the first ones and is usually not used. Then there is a word doc for the newer ones. I know I tried setting mine with the pdf version and it just wouldn't work.
Old 02-25-2013, 03:21 PM   #28 (permalink)
Always Learning
mikeyVR4's Avatar
Okay I will start the troubleshooting by disconnecting the MAFT 2.02 and plugging in the factory MAF harness to the MAF. I will check the readings on my WB and see if anything changes. I will report back soon.
Thanks.
Old 02-25-2013, 05:00 PM   #29 (permalink)
Aww just a base..
New video.
MVI 2565 - YouTube
Ex:
Ne1: 800 (lowest)
Ne2: 1200 (lowest)
ne3: 1600 (lowest)
etc.
This is perfect. The settings on your SAFCII are no longer the issue. 1 possibility down.
Old 02-25-2013, 05:02 PM   #30 (permalink)
Always Learning
mikeyVR4's Avatar
Yes that is a relief unless its a wiring issue. Definitely have a gremlin in the system but I will start troubleshooting in about 30 minutes when I am off of work.
