Old 11-01-2009, 02:31 PM   #11 (permalink)
Spartan for Life!
aaronatstate's Avatar
Drives: A Dodge Import.
Trader Rating: (9)
aaronatstate Level 1aaronatstate Level 1
Default Re: Rebuild ?'s, Gasket set, pistons choices.
Originally Posted by TwIzTeD_3kGt View Post
I wouldn't.
Why are you rebuilding? Just to rebuild? Or did something break?
I'm reusing stock rods. Though I'm only going with the 13t's, unlike you and your 19t's. Stock rods will be enough for me.
January 2009 - ROTM
I have an 18 spline VCU for sale. -375 shipped.
aaronatstate is offline   Reply With Quote
Old 11-01-2009, 03:30 PM   #12 (permalink)
RealMcCoy's Avatar
Drives: 92 RT/TT, 96 Cobra
Trader Rating: (22)
RealMcCoy Level 1RealMcCoy Level 1RealMcCoy Level 1
I may be wrong, but it's my understanding that the stock turbo piston was a hypereutectic alloy. Most of the aftermarket replacements such as the Sealed Power/ Speed-Pro, and others are hypereutectic as well. The pistons in that link are advertised only as being cast, so there's a good chance they are actually a downgrade from stock.
Because One broken Stealth just wasn't enough... I made twins..
RealMcCoy is online now   Reply With Quote
Old 11-01-2009, 04:39 PM   #13 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (217)
Yes, the stockers are hypereutectic.
-Chris
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-770AWHP 747AWTQ 30psi E100 Daily Driver 10.57@136mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Import Power is online now   Reply With Quote
Old 11-02-2009, 12:25 AM   #14 (permalink)
Wingo171's Avatar
Drives: 91 VR4, 08 ZX14
Wingo171 is an unknown quantity at this point
I don't have anymore information from looking, but these may help you if you choose to go stock.
Speed-Pro Hypereutectic Pistons - SummitRacing.com
Wingo171 is offline   Reply With Quote
Old 11-02-2009, 02:43 AM   #15 (permalink)
Woz
Woz is an unknown quantity at this point
re read import power. do exactly what he says ! most gaskets are one time use, i would never re use a gasket. and yes, clean until you take a white cloth and rub it and it is still white, then you know your safe !!
Woz is offline   Reply With Quote
Old 11-06-2009, 03:44 PM   #16 (permalink)
AAPStealth
aapstealth's Avatar
Drives: 1995 3000GT
aapstealth is an unknown quantity at this point
Bump Does anyone have a link for that OEM gasket set for $320? Also does it include all gaskets from Oil pan up? If so $320 is a pretty good deal on a true full gasket Kit.
Also does anyone know if the pistons used By Pricedmatchedparts on their stage 1 rebuild are any good?
becasue they have pretty good deals on rebuilt Short blocks.
aapstealth is offline   Reply With Quote
Old 11-06-2009, 10:29 PM   #17 (permalink)
Budget Builder
Bluejediz's Avatar
Drives: '91 Dodge Stealth TT
Bluejediz is an unknown quantity at this point
I wouldn't.
Just rebuilding to rebuild, 170,000 on the clock. I figure since im planning on keeping the car for a great while and want to eventually hit the 500hp mark it would be better to use the money and rebuild the engine rather than start slapping turbos on and possibly have to do a forced rebuild.
Oh, I did a quick compression check a few days back, Only did the front 3 cylinders cuz i didnt have a whole lot of time. My results were:
Cyl 1: 125 (dry) 130 (wet)
Cyl 3: 100 (dry) 110 (wet)
Cyl 5: 125 (dry) 140 (wet)
Thats after 6 strokes.....The specs I found were 115psi.
I then did a running compression check. As i recall you are suppose to get %50 of whatever you got for the dry check at idle and around %80 at snap throttle, Thats on NA cars anyways. I was getting about 25psi at idle and maybe 40psi at snap. Is it diffferent for turboed cars cuz of all the stuff in between the intake and the throttle body (turbos, intercooler, etc)?? Or is the engine just not breathing very good?
Bluejediz is offline   Reply With Quote
Old 11-07-2009, 12:08 AM   #18 (permalink)
Spartan for Life!
Trader Rating: (9)
If you plan on going for 500hp, get forged pistons now. You'll thank yourself later when you dont have to pull the engine apart again to replace a cracked piston.
Old 11-07-2009, 08:26 AM   #19 (permalink)
That is not spec, that is the service limit and the sign of a VERY worn engine. A TT should compression at 145-165psi
-Chris
Old 11-07-2009, 11:19 AM   #20 (permalink)
Drives: 91 GTO TT
caswell239 is an unknown quantity at this point
3sx>gaskets and seals> top left one OEM gaskets. Then select dohc tt for 369.99
1991 GTO TT
blown engine
caswell239 is offline   Reply With Quote
