questions on injectors and tuning
Okay so the 560cc evos are no good on the stock ecu, as far as I've read, so what 550s are good on our cars, I'm going to run pump gas with meth inject, 13ts with a maf translator blow thru and safc for tuning. I have a supra pump installed, no fpr, not having issues with it yet, ill get on eventually though. So what suggestions do you have on the injectors and my tuning, what 550s are good and idle smooth in our cars, and should I abandon the safc and just run a blow thru and emanage blue setup. I want to keep it simple to start with this setup. Thanks alot
