Old 02-07-2004, 10:50 AM   #11 (permalink)
Long Time Member
starkeyje's Avatar
Drives: 91 Stealth TT
starkeyje is an unknown quantity at this point
Default Re: Question about the o-ring on the rear turbo IC pipe
I had a hell of a time with the O-Ring on my rear turbo DN hardpipe. I tried all the tricks, and nothing worked. I ended up using a dremel to shave down the inside of the O-Ring just enough so it would fit tightly into the rear turbo housing. Then, I put an O-Ring down into the turbo housing itself, so the hardpipe would crush onto it when tightened down. No leaks. Also, to keep the O-ring pliable under the extremely high temperatures generated by the turbo, you should use synthetic grease, i.e., the silicone stuff that they put on brakes.
Hope that helps.
1991 Stealth TT
- Pocketlogger
- DNPerformance Hardpipes
- DNPerformance Turbo Pipes
- Alamo Downpipe
- K&N Filtercharger
- Polished Intake & Valve Cover
- Indiglo Gauges
- Custom Stereo and Speakers (Kenwood w/ Polks & Bazookas)
- Defi VSD-II
- HoseTech
- Blitz SBC-ID
- Blitz Power Meter ID
- H4 Headlight Conversion
- Lighted Winshield Washers
- SSR GT3s wrapped in Bridgestone Pole Positions
- Brembo Slotted/Dimpled Rotors
2000 Audi A4 1.8T
2003 Yamaha V-Star 1100 Classic
starkeyje is offline   Reply With Quote
