| View Poll Results: do it or not? | |||
| Yes, quad turbo FTW!!! |
16 | 26.23% |
| thats crazy. waste of time. forget it. |
31 | 50.82% |
| damn Ukrainians.... |
14 | 22.95% |
| Voters: 61. You may not vote on this poll | |||
LinkBack | Thread Tools |
#11 (permalink) | |
Can't say *****?
#12 (permalink) |
Spartan for Life!
So you are going to have 1.5 cylinders powering each turbo. How exactly do you plan to even set it up? Run half a pipe from the center cylinder to each turbo on a bank? Not a very good idea.
![]() I have an 18 spline VCU for sale. -375 shipped. |
#13 (permalink) | |
Driving While Ukrainian
both turbos get 3 cylinder, not 1.5 each.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs. Working on: Driver mod. E85 powered VR4 since 09/2006 For Sale: stock injectors and pump, SMICs, BOV. Looking for: ISC motor. Quote:
#15 (permalink) |
Paid Member
did you want to run each turbo independently or flow the compressed air from one turbo to spool up the other. maybe a 9b used to spool a larger turbo would be neat.
i wouldnt say dont do it, because its your call. if you did it, and it worked, all the nay-sayers would be impressed. its up to you. but it will be expensive and difficult given the amount of room available in the engine bay. good luck either way
92 sandstone vr4
dr-500 turbos custom made exhaust fipk walbro fuel pump more to come |
#16 (permalink) |
I don't want to separate exhaust for each turbo. 3 cylinders will give exhaust and than I'll split the exhaust to both turbos. I think its better than having 1.5 cylinder per turbo. and having 1 cylinder work for both.
this is just an idea. I don't even know if its gonna work. |
#17 (permalink) | |
I am McLovin!
I think he means 2 turbos off 1 manifold, I hope! If your worrying about spool time and want a quad set-up your best bet I think would be a sequential set-up. Still impossible to fit in the bay, but much more useful than the original idea. Quad parallel turbo's is awfully impractical unless you have a W16! Which is essentially very efficient due to the fact that each turbo gets a 4 cylinder bank.
#18 (permalink) | |
Spartan for Life!
#19 (permalink) |
The Student
Just to throw in an engineers perspective........this is a sweet idea, and id be very impressed if you made it work. Now for the downside. If you run 2 of the same turbos on each side of the engine....you will only have minimal power gains. The reason being that you cant just add the amount each single turbo outputs together and get one total PSI sum. Plus, each turbo will take longer to spool as previously mentioned. Even though this will be minimal.....
The main issue you have will be the PSI gains. They WILL NOT pull 25psi to the redline......and THEN you have to worry about cooling. As previously mentioned....4 9Bs are very inefficient......which means lots of heat for minimal gains. The turbos will get very very hot and to make a cooling system that would work would be hell. Overall, bad idea......but good concept. Go for a sequential setup (if you have 20k to blow) |
#20 (permalink) | |
Here for the tuna.
How come nobody else read my post? ![]()
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts Nov 2008 ROTM ![]() |
| Thread Tools | |
