#51 (permalink) | |
I think this is a reasonable issue to raise. I have a question about an O2 sensor reading rich if there is a misfire. The O2 sensor responds to the O2 partial pressure in the exhaust stream. If there is a misfire, gas isn't burned and there should be more O2 or a higher partial pressure. This would yield a lower voltage signal and be interpreted as a lean condition. If there is flaw in my logic, I 'd like to understand. As far as the behavior of my engine there isn't any indication of any misfire. The A/F on the wideband deviates at the slightest pulsing. I'll have to think about this some more, but I think the A/F shift is from the pulsing and not the cause. I'm going to try just using a straight 6mm hose as a bypass when I go out this weekend. Given the input so far, this seems like a reasonable thing to try. Jeff |
#52 (permalink) | |
GoFast Crackpipe Junkie
I guess that's what I get for allowing the fingers to hit the keyboard without the clutch for the brain being engaged... I'll go sit in the corner for a time-out.It's a longer shot, but overly rich mixtures can also cause misfires, so the cycle might be able to work that way. My understanding, though, is that it has to be REALLY rich to cause a misfire, and I'd suspect that isn't happening here. Back to the drawing board... --Erik
'95 White on Black VR-4
http://www.rubberduckyracing.com |
#53 (permalink) | |
Moderator
That certainly can and does happen. That is what my car was doing. Stupid rich and actually misfired and sent the ECU into limp mode. However, I agree that is not part of the problem at hand as my car will pulse...rich, lean or indifferent.... Jeremy |
#54 (permalink) |
So what do DR or GTPRO or the other big shops do when a car with this problem rolls in?
Tell them that it's unfixable and send them out? They must have a solution - if they don't, I am clearly mislead on their expertise regarding our platform. This seems to be a fairly common problem among 3s cars. I appreciate all the work jeff is putting in but I'm surprised the big boys haven't stepped in and said anything. They are always there to give advice on bigger turbos, exhaust, and clutch setups - I would hope that they would at least have more to add on this topic. More on-topic, I've been messing with this situation for about a year and have found the same results. Relevant mods: td04hl 15g's, cc 8inch fmic setup, hks ssq bov in recirc, dejon tool intake pipes With these mods, the car pulsed like CRAZY. If you weren't WOT, it was pulsing. And yes, I pressure tested the crap out of that thing - it was sealed tightly. I removed the HKS bov and replaced it with the stocker and the pulsing just got worse. I tried my Greddy Type S from my 2g awd dsm and it was just as bad - probaly worse. At this point, I realized that the pulsing was unstoppable and was hoping that it was a drawback of the cc fmic kit. So I sold the kit and went back to stock. With the stock intercoolers and HKS bov, the surging is much more tame. It only occurs during cruising at low rpm at partial throttle. It is the worst on the highway in 5th gear under 2.5k. If I go WOT and drive in bursts, I can avoid it. This is a serious problem and deserves more attention than it has recieved imo. I KNOW that a lot of people w/ upgraded intake/intercooler systems have this problem and just let it go and drive with the pulsing. I'm really interested in what the big shops do when someone comes in with this problem. I appreciate your R&D Jeff - I'm going to be giving the modified HKS BOV a try when it warms up. I just hope it isn't detrimental to the overall power output of the car
92 VR4 = Driveway Ornament
#55 (permalink) |
Weekend report, this is what I tried on Saturday, Jan 22.
1. Straight 6mm hose from y-pipe to intake elbow. This seemed worse than the hose with the solenoid, which is a restriction. I thought this would be better because more air could bleed off. The pulsing would continue until the pressure in the y-pipe dropped to about 2.5psi. 2. If 6mm couldn’t release enough air, 8mm should be better. Silver soldered a 5/16 fitting in the y-pipe and the copper el adapter and ran an 8mm hose. This was about the same as with the 6mm hose, except it threw PO0170 andPO0173 error codes, front and back fuel trims. I’m not sure why the codes were thrown, the engine ran fine and the A/F was in the normal range. It was probably some transient from all of the air that was being bypassed. 3. Loosened the BOV spring pressure with the 8mm hose to see if there was an effect. No change. 4. Went back to the 6mm hose with the Hobbs switch controlled solenoid. This seemed to be the best setup. There is some pulsing but it seems to damp out faster than the straight hose. I want to try this setup earlier in the day when it is colder to make sure that warmer temperatures in the afternoon aren’t the reason for the improved behavior. I still want to try the bigger solenoid on order to see if that is an improvement over the smaller, more restrictive one in use now. I won’t know until it arrives, but I suspect it will be more restrictive than a straight hose. The Hobbs switch will control the opening and closing of the bigger valve. I may not try it before I go to Phoenix next weekend since the present setup seems to work very well. I am guessing that the larger opening was bypassing too much air and the throttle had to be held open more which in turn pushes the turbos to make more boost. Having the right sized leak is the goal. I wonder how the bypass will work with a Greddy s type push BOV. At some time I will convert my modified HKS valve back to the stock configuration and see how it behaves. Right now I am getting tired of this. Each trial drive takes about 35 minutes if I have to return home and about 20 minutes if I can make the change at the side of the road. If the weather is decent next weekend, I will drive the car to Phoenix and will have a chance to observe behavior over an extended time with different load conditions. I will adjust the Hobbs switch pressure turn-on and the BOV spring pressure to get some feel for the sensitivity of those parameters on the pulsing. If anyone were interested in doing this mod, I would strongly urge monitoring y-pipe pressure and O2 readings, either factory ND or WB. A simple pressure gauge teed at the y-pipe nipple in front of the throttle body is all that is needed, vacuum reading aren’t needed. You will be able to observe the pressure in the y-pipe when the pulsing occurs and compare that to the plenum pressure from your standard boost gauge. You can get some idea of how fast the pressure drops when the BOV opens. I also hooked up a DVM to the front factory NB O2 sensor. When the WB indicated the A/F dropped to 12.5-13 from 14.7(dithering), the NB went from dithering to a steady reading around 0.9V. Either a WB or NB could be used. Jeff |
#56 (permalink) | |||||
Jeff |
#57 (permalink) |
Drove the car this morning, it was only about 20 degrees cooler than yesterday afternoon, but the car was also cold to start. The pulsing was about the same as yesterday afternoon. This is with the 6mm hose, small solenoid valve, Hobbs set at 4 psi, and BOV spring backed off.
Something I had misinterpreted was the pressure measurement across the throttle body, from the y-pipe to the plenum. The differential pressure measurement would also pulse. Thinking about this, it became obvious that the pulsing was being influenced by the throttle body. I hooked up the 3.6-psi differential gauge across the throttle body. The pulsing seems to start there. The pulses start as the throttle is partially closed and can increase in magnitude. I am suspicious that the pulsing that has to be occurring in the plenum is the cause. As the airflow is slightly interrupted at part throttle with some positive pressure in the y-pipe, the pulsing in the plenum becomes unstable and is driving the whole process. I need to observe this for a while to see if the plenum pressure is about the same when the pulsing starts. It is possible that there is a resonance in the plenum design that is driving this phenomenon. More data is needed. Since I have an idea now of what to look for, the perfect opportunity comes up next weekend during my drive to Phoenix. The reason for the trip is to watch NHRA Top Fuel Dragsters and Funny Cars make tuning passes. I can’t wait, the chance to drive the car on a road trip and watch real horsepower be produced. Jeff |
#58 (permalink) |
Gear Head
Hey cool NHRA! If the opertunity comes up maybe you could talk to a guys there about this situation and see what they think?
I have been following this problem for a while now and I noticed some people don't quit have the same symptoms and some have found numerous solutions. I was brain storming (okay more like a light drizzle), and thought maybe for some of you it's the hard pipes that are causing this problem? woovr492 - You mentioned you had the CC FMIC kit. It can be bought with a hard pipe kit. Could you try switching as many of those hard pipes over to a soft pipe to see what the results are? My thinking behind this was if the soft pipes could expand with the pressure pulsing it would dampen the pulses and maybe even eliminate them completely.
250 RWHP If you want the exploded views of both 5 and 6 speeds or pics e-mail me at SavagTiger@AOL.com. 94 VR-4 Panama Green Tan Interior RPS II, gutted cats, flipped BPV, 3SX control arms, 3SX shift bushings, Red Line, Auto-Meter. Rebuilt TC, transaxle, steering rack, heads, and turbos. 360cc's blue printened with in 1%. New short block. RWD convertion and welded rear end. |
#59 (permalink) | |
I have been following this problem for a while too. I have all stock intercoolers and pipes and I still have the problem. I never had it with the stock BPV, but it started when I installed my Greddy BOV. I have stock turbos and my upgrades include a HKS intake, HKS boost controller, and exhaust. Other than that, my car is pretty much stock. I am meeting with VR4neophyte this weekend to swap ECUs. Before we do that I will reproduce the problem in my car for him to see if it feels the same as what he is experiencing with his car with upgraded intercooler pipes. I know Erik Gross and I have the same problem because he has sat in my car and seen what I am talking about. He had the same symptoms with his Greddy BOV when it was installed.
-Mike Quote:
#60 (permalink) | |
Wanted: Traction Problems
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
