Old 05-05-2008, 01:12 PM   #1 (permalink)
chrome is an unknown quantity at this point
Default Please HELP before wed.....ignition,turbos,driveshaft.
I searched first and found a few related problems but never got a straight answer.
OK basically the car wont start! when i bought it a week or so ago it had the problem of sometimes when you turn the key forward it started fine, but most of the time you turn it forward you get nothing not even a hesitation or a click click click start just blank.Now i tried for over an hour 3 days in a row and no start. The only thing that happens is the radio goes blank. If you turn the key on for a few seconds and then back off you hear the click sound on the passenger side consol so ie MFI is working. Next i checked all the fuses and relays under the hood the MPI/ECI was good. A local mechanic is comming to pick up the car wed. to put a new ignition in it but i have a feeling thats not the problem. And when the key did work sometimes it started quickly with no hesitation, so i think the starter works fine. I read on here it could be the ECU how would i check this? Or what else could it be?
Also while he is doing this i am having him fix 2 other MAJOR problems.
So the car smokes blue smoke (oil i know) from the exhaust very heavily during idle (not sure while driving i dont see any) but i knopw the previous guy had cranked up the boos between 14-19 psi on the stock turbos. It also is using a lot of oil. now the motor runs quiet with no typical DSM tick (idle at about 1100 though) 61K on motor.so im pretty sure that it blew the turbo seals out so so i've heard this is about 11-12 hours labor to replace turbos not including any parts just labor. I am in kansas city, mo and cant seem to find any rebuilt turbos/ direct replacements i.e. TDO4,WRX or what i would really like is a pair of 15G. Is it hard to replace the seals myself? and how much does this job typically cost to do including parts?
OK on to the last of the major problems.....
There is a mild to heavy vibration in my powertrain under load i can be cruising down the highway at 70 or so and if i push the clutch in it rolls smooth as butter but as soon as i give it ANY throttle it starts to vibrate (not the car really just the what i assume feels like the driveshaft or something) Especially rough at under 3K rpm's. I have been told wheel bearings, carrier bearings, and U-joints.....WHat would you suggest?
chrome is offline   Reply With Quote
Old 05-05-2008, 02:03 PM   #2 (permalink)
Forest Gump
cbehnken's Avatar
Drives: 1992 Stealth TT
Trader Rating: (41)
cbehnken level 6cbehnken level 6cbehnken level 6cbehnken level 6cbehnken level 6cbehnken level 6
Default Re: Please HELP before wed.....ignition,turbos,driveshaft.
didn't have time to read everything, but for the starting problem search for "click click start fix".
Basically the ignition key switch is worn out. You can replace it or get a piggyback relay to "fix" the problem.
Roll start the car and you will know for sure. Get the car rolling 5-10 MPH and let the clutch out in gear with the key ON.
cbehnken is offline   Reply With Quote
Old 05-05-2008, 02:26 PM   #3 (permalink)
thanks! but like i said its not the click click click its a turn key nothing problem
Old 05-05-2008, 02:31 PM   #4 (permalink)
Forest Gump
cbehnken's Avatar
Trader Rating: (41)
same thing probably. Try the roll starting.
Old 05-05-2008, 06:42 PM   #5 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
With the no click start thing, try this. Take off the steering column plastic guards by releasing the screws underneath the column and removing the garnish. First, take a look at the left side of the column opposite the key side of the cylinder. There is a black cap with wires soldered to it. There is one screw which keeps it tight. Make sure its not loose. If its not loose, then look at the key side and look for the small hole right on the outside of the cylinder. With the key in the accessory position, and the pin in that hole pushed in, you should be able to pull the whole key cylinder out and you can inspect the copper traces and see if they are worn out. If they are, you need to replace the assembly. Thats all I got. My car was doing this and mine was loose and worn out, so I drilled out the old one, and installed a new one for $80 and re-used my old key cylinder since it was still good.
Sam
wraith is offline   Reply With Quote
Old 05-07-2008, 02:40 AM   #6 (permalink)
Well i took the column garnish off and that screw seemed to be ok i just tapped on it to see if it was real loose. i assume i have to take that under garnish with the little vent underneath off to toget to the screw and test it. and when i pull the ignition lock out to see if its warn what do you mean what should i look for exactly? And how do i check if its my ECU?
