Old 05-24-2004, 07:31 PM   #21 (permalink)
old skool yo
Drives: '01 Excursion Diesel
msaskin is an unknown quantity at this point
Default Re: p0300 CE code
ding ding ding...I win...I told you the problem was indicative of a coil pack
Can't help you about the TT vs. N/A thing though, call the dealership and check part numbers?
~matt
2001 Ford Excursion Limited: Powerstroke Diesel
Looking for another 3/s...
msaskin is offline   Reply With Quote
Old 05-24-2004, 07:39 PM   #22 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (41)
DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4
~matt
CAPS!
Get yer ass back to NY
DJAuggie is offline   Reply With Quote
Old 05-25-2004, 08:19 AM   #23 (permalink)
Mellon's Avatar
Drives: 91 TT Stealth 05 EVO
Trader Rating: (18)
Mellon Level 3Mellon Level 3Mellon Level 3Mellon Level 3
sounds like you're on to something DJ good to hear.
- Chris
05 EVO and 91 Stealth R/T TT
**video**
Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com
Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC
Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI
Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter
Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump
Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers
Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts
Other: Unorthodox Underdrive Pulley, Krankvents
Mellon is offline   Reply With Quote
Old 05-26-2004, 06:53 AM   #24 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
Replaced the coil pack with BIG_BALLER's 94 BASE coil pack and the car still ran like shit. I replaced the power transistor with BIG_BALLER's 94 BASE power transistor and the car started right up. I cleared the code and drove it 10 miles and the car ran great!
What's the chances of it being BOTH the power transistor and the coil?
I got a power transistor coming 2-Day. That's definately toast but what about the coil? Visually, I didn't notice anything on the coil but I didn't pull the power transistor, I just hooked up BIG_BALLER's and let that shit dangle
Old 05-10-2008, 12:54 AM   #25 (permalink)
MI SCUZI! MI SCUZI!
NeoValentine's Avatar
Drives: Twin Turbo SL
Trader Rating: (40)
NeoValentine Level 3NeoValentine Level 3NeoValentine Level 3NeoValentine Level 3
Thread from he dead. i'm getting the same p0400 all the time, running a brand poil pack ad ptu any advivr.?
R.I.P. Beastly-SRT 2/21/08 9:04AM-2/21/08 2:27PM
NeoValentine is offline   Reply With Quote
Old 05-30-2008, 08:57 AM   #26 (permalink)
MI SCUZI! MI SCUZI!
Trader Rating: (40)
Note to self don't post while hopped up on Pain Meds and other things... Anyways, has anyone else had this issue and what cured it, I get it every few days or so, but it doesn't cause any issue, car is still 100% driveable, just the CEL keeps popping up.
