Old 05-24-2004, 07:09 AM   #11 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (41)
DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4DJAuggie Level 4
Default Re: p0300 CE code
Originally Posted by Feral
Do you still have your old plug wires? Also I think an air leak is HIGHLY suspect myself ... but its hard to tell. What did you specifically change before and after? I know you have been doing some mods to the car recently.
Last summer when you installed my Supra FP, I installed the MSD wires one week before. That was 10,000 miles ago (that HURTS). I installed the LS6 MAS/MAF-T and hotwired the FP Erik Gross style with Matt Saskin since the turbos. I've also went to the track once with the LS6 MAS and once with the LS6 MAS/MAF-T/FP combo.
If it is a massive air leak, then I don't understand why the car started RIGHT up after sitting over night for a couple of minutes, the CEL come on and me clearing it bringing it back to normal (02s cycling too), and then 2 minutes later the CEL comes on and back to the original problem with the 02s NOT cycling.
DJAuggie is offline   Reply With Quote
Old 05-24-2004, 07:18 AM   #12 (permalink)
Play that Funky Music
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (209)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
DO a pressure test. Do you have a coil pack to swap from a working buddie's car? How about a working ECU from another car also. It's time to start doing the process of elimination. And after doing a pressure test if that turns out ok you need to start swapping out components to see if one is bad.
Bad IAC Stepper motor can make it go haywire also. What are youe ICS steps on the logger? THey should start high cold then settle to under 20 and in the teens when fully warm, unless you click on the AC or turn the wheels all teh way wich trips the PS up idle switch.
AEM Factory Trained Tuner
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T4-995AWHP Uncorrected 6G72 3.0L
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
91VR4 Black-5027s-3.0L-Stock heads and Cams- 614AWHP 557AWTQ uncorrected 24psi Daily Driver
3SX Performance
3SX Performance Service Email
Old 05-24-2004, 07:22 AM   #13 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
Hm. There's not many 3/S TTs in the area. There's 92VR4NY which I won't touch (no offense Mike) and Anubis's 92 RT/TT. Oh, AllEyezOnMyVR-4 (Frank) but his car is gone for weeks while being painted. Does it matter what year? Same for ECU?
ICS? I don't have that option on my OBDII datalogger I don't think.
Old 05-24-2004, 08:48 AM   #14 (permalink)
vehicular thaumaturgist
Multiades's Avatar
Drives: 1994 Stealth TT
Multiades is an unknown quantity at this point
Originally Posted by DJAuggie
I limped the car home with I'm a dork. Anubis came over and we swapped the MAF-T for the stock MAF and no change. We started to rip down the plenum to get to the plugs.
I'm not one bit surprised about this -- all of your basic correction is done in the Translator -- you would need to swap in the stock MAS AND correct with the S-AFC for the basic injector correction (about -34% across the board).
-Chris
The Pansy Patrol - a 3000GT/Stealth car blog with how-tos
Pearl Yellow 1994 R/T TT w/84k - FOR SALE! new 4-Bolt factory short block, DR StgII heads, Titan TD05 headers, 14B turbos w/ ported 7cm^2 housings, 3" minimum-bend catless exhaust, SCE oil pan, RPSII clutch, Fidenza flywheel, OZ F1 Plus 17x9.5" wheels, Kumho Ecsta MX 245/45 tires, Drweldin DSM SMICs, 3SX engine mounts (Maximal solid front), GReddy 60mm P/H/W boost, Carbotech Panther Plus & Bobcat pads w/ slotted/drilled rotors, KSport GT-Pro coilovers, Maximal rear camber arms, SCE balljoints, ABS delete w/ cockpit-mounted Wilwood proportioning valve, AC delete, EGR/evap/dashpot delete, cruise/vacuum-tank delete, '95 Lexan headlights, McCulloch 4300K HIDs, GReddy Type-S BOV, solid shift bushings; Misc Parts: Walbro341, 20# fixed-back seats, Accelerated Moto catch can
Multiades is offline   Reply With Quote
Old 05-24-2004, 08:52 AM   #15 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
-Chris
I went back to my old fuel maps when I did this. -36 across the boards with my LOW fuel settings when just using the 550CC/Stock MAF. With that said, I still had the shitty AF settings of .06 and .12 (REALLY lean)
Old 05-24-2004, 08:55 AM   #16 (permalink)
Multiades's Avatar
I figured you would have mentioned doing that part -- oops!
Could be a fuel pump problem. You don't have a pressure gage I take it...
-Chris
Old 05-24-2004, 09:03 AM   #17 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
-Chris
Nope. I got my hands on a voltmeter. My Supra buddy told me it MIGHT be the Supra FP which had 70K (supposedly) and I got 10K on it. I recently did the Erik Gross rewire but driven it a month or so including the track and datalogged it plenty since.
Is checking that at the FP a difficult job?
Old 05-24-2004, 09:14 AM   #18 (permalink)
POLYCHRONOPOULOS
RobBeck's Avatar
Drives: On 1 Wheel
Trader Rating: (216)
RobBeck is an unknown quantity at this point
You really need a fuel pressure gauge in the cockpit if you want to confirm the pump and system is acting as it should.
RobBeck is offline   Reply With Quote
Old 05-24-2004, 11:15 AM   #19 (permalink)
Searching for Prey
Feral's Avatar
Feral is an unknown quantity at this point
Nope not at all ... you just yank the inspection panel and splice into the voltage ... or even easier check the voltage out of the gross re-wire (it will be maybe .5 volts less at the pump ... anything over 10 volts will make enough pressure for the car to idle well though).
Oh ... did you check your alternator output voltage? Make sure its over 13.
All go no show kind of guy
Bolt-on Warrior
Hunter Green '94 VR4. 1/4 11.816@118.26 at 18.4psi; 1/8 7.615@91.68
DR650's/DSBC/Greddy Type R BOV
DR's Propane Injection/ARC2/87mm MAS/K&N/660CC/Denso/Boosta Pump
Kormex 6spd/Fidanza Flywheel/RPS Max
Accel Coils/Boosta Spark/Copper Plugs
Porterfield X-drilled, cryo treated/R4-S pads/SS brakelines
Emissionsless 3" turbo-back exhaust
UDP, KrankVent, a pile of guages, Redline everything.
Primer Black (yeah!!) '92 RT/TT
~3,300lbs (still aiming for <3,000)
S-AFC/450CC/Walbro
K+N/TurboXS BOV/MBC@15psi
Emissionsless stock exhaust
Very broken clutch and tranny
(Driven into 8" curb at 50mph) mod
3SI #1013
My shop
Feral is offline   Reply With Quote
Old 05-24-2004, 07:05 PM   #20 (permalink)
RESIDENT ASSHOLE
DJAuggie's Avatar
Trader Rating: (41)
Thumbs up Re: p0300 CE code
Good news!
I started the car and it ran NICE. The 02s were cycling and the CEL was cleared and stayed away. After 2 minutes, the car went back to running on 4 cylinders (I know it's 4 now) and the CEL P0300 came back. I started to pull plugs off the coil pack.
The first 4 showed a NICE spark that went right to the valve cover including my hand. The engine showed signs of loss of cylinder and spark was definately visible. The last 2 on the same coil pack towards the BOTTOM resulted in NO visible spark and no change in engine noise.
It seems my car is running on 4 cylinders. I am going to swap in another coil pack. Do all TT and NA use the same coil pack? Anyone got any other ideas?
Looks like I am on the right track. Thanks to everyone.
