#21 (permalink) |
old skool yo
ding ding ding...I win...I told you the problem was indicative of a coil pack
![]() Can't help you about the TT vs. N/A thing though, call the dealership and check part numbers? ~matt
2001 Ford Excursion Limited: Powerstroke Diesel Looking for another 3/s... |
#22 (permalink) | |
RESIDENT ASSHOLE
Get yer ass back to NY ![]()
#23 (permalink) |
sounds like you're on to something DJ good to hear.
- Chris
05 EVO and 91 Stealth R/T TT ![]() **video** Upload your 3/S videos here http://3svideo.vidiac.com and post www.racevideoforums.com Intake: E16G turbos, DR Stage III heads, DR Race cams, Unorthodox Cam gears, Stock MAS, 6" K&N air filter, HKS SSBOV, Vacuum Reduction, custom 2.5" intake pipes and Dejon FMIC Ignition: MSD 8.5mm spark plug wires, NGK non-resistor non-projected R5671A-8 gapped at .026, HKS Twin Power DLI Electronics: Greddy Turbo Timer, Greddy E-Manage Blue, Greddy Profec E-01, MMCD and Palm, LM-1 Wideband + RPM Converter Fuel: Blitz 720cc injectors, Denso 310lph fuel pump, Fuel pump Hotwire , relay bypass, IPO SX Fuel Pressure Regulator and Kenne Bell Boost-a-pump Exhaust: Titan TD05 Headers and 02 housings, EGR Blockoff Plates, ATR downpipe, Twin Borla mufflers Driveline: RPS MAX 6-Puck Clutch and RPS Flywheel, 17" Enkei RPF1 (16lbs each), Nitto 555 Extreme, TEIN S-Tech springs and KYB GR2 Struts Other: Unorthodox Underdrive Pulley, Krankvents |
#24 (permalink) |
RESIDENT ASSHOLE
Replaced the coil pack with BIG_BALLER's 94 BASE coil pack and the car still ran like shit. I replaced the power transistor with BIG_BALLER's 94 BASE power transistor and the car started right up. I cleared the code and drove it 10 miles and the car ran great!
What's the chances of it being BOTH the power transistor and the coil? I got a power transistor coming 2-Day. That's definately toast but what about the coil? Visually, I didn't notice anything on the coil but I didn't pull the power transistor, I just hooked up BIG_BALLER's and let that shit dangle ![]() |
#26 (permalink) |
MI SCUZI! MI SCUZI!
Note to self don't post while hopped up on Pain Meds and other things... Anyways, has anyone else had this issue and what cured it, I get it every few days or so, but it doesn't cause any issue, car is still 100% driveable, just the CEL keeps popping up.
