Oil in the wheel well?????? - 3000GT/Stealth International Message Center
Auto Insurance
Wheel & Tire Center
Old 08-31-2004, 07:34 AM   #1 (permalink)
mugs's Avatar
mugs is an unknown quantity at this point
Feedback Score: 0 reviews
Default Oil in the wheel well??????
OK, I just left work this morning and was looking at my car and noticed that my front left wheel well is full of oil. It must be spraying out somewhere in there because the bottom of my oil pan is dry and so is the area around the oil filter.
Could I have blown a line somewhere ?? My oil pressure was running at the normal level and I topped it up before I drove 3000 meters and parked the car at my parents. Its spraying so bad that oil is coming out between the quater panels on the front of the car.
Any help with diagnosing this problem would be greatly appreciated.
Thanks in advance to anyone who takes a moment to help me out.
Some people are alive simply because it's illegal to kill them!!
If I help you out, please help make the community better and pay it forward.
mugs is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 07:39 AM   #2 (permalink)
No loer a Noob?
skunkworks's Avatar
Drives: low impedance inputs
skunkworks is an unknown quantity at this point
Feedback Score: 9 reviews
Default Re: Oil in the wheel well??????
drivers side?
oil cooler lines <- most likely
oil cooler
oil filter - had one squese out the side once.
those are the most common
sam
92 Stealth R/T TT - 13t's Installed. note:Is the machining right? - boosting to 15psi so far.
Do I do this for others? No. robbeck is your man.... We know his work
skunkworks is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 07:49 AM   #3 (permalink)
mugs's Avatar
Yes it was my drivers side.
I ran my hand around the oil filter and it was dry. But the oil cooler lines and oil cooler are both good ideas. It was just the amount of spray coming out that amazed me. To have oil coming out from between body panels is something I have never seen before. Thanks for the ideas. My mechanics is still closed right now, so I can't even call him yet. I hope it just looks worse than it actually is.
Old 08-31-2004, 08:16 AM   #4 (permalink)
RichardRTTT's Avatar
Drives: 92 Stealth R/T TT
RichardRTTT is an unknown quantity at this point
Feedback Score: 1 reviews
Is it oil or grease? If a CV joint boot split open it would spray grease around the whole wheel well.
...or you could have developed an intercooler boost leak and you're blowing out oil that has collected.
Performance Mods:
K&N Intake, Two Stage Boostvalve MBC@6psi/14psi, SPW Boost Gauge, SSQV BOV, Gutted All Cats, 3SX Downpipe, S-AFC GEN I, NGK Ferrite Magnetic Core Wires, NGK BKR6EGP Plugs, E2KMFG Fuel Rail Adaptor, Stillen Brake Pads, EGR Blockoff Plates, Krank Vents, Redline Drivetrain Fluids.
Other Mods: Infinity Kappa Speakers Front and Rear, Pirelli Pzero Nero M+S Tires, Katzkins Leather Seat Covers, Factory Gear Shifter, Dashmat.
To Buy: Bigger Injectors, Fuel Pump, FPR, Upgrade Turbos.
RichardRTTT is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 08:32 AM   #5 (permalink)
Go Mountaineers!!
HilbillyHomeboy's Avatar
Drives: Tin Indian
HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2HilbillyHomeboy Level 2
Feedback Score: 39 reviews
Would be my first guess.
Jeremy
HilbillyHomeboy is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 08:48 AM   #6 (permalink)
Member # 2818
cred05's Avatar
Drives: 2000 Audi S4
cred05 is an unknown quantity at this point
Feedback Score: 4 reviews
Are you sure its not brake fluid? It happened to me, my front driver's side wheel was full of "oil" and i have aftermarket rims and the paint started to flake off. And i know that brake fluid eats paint. If you have stock rims it wont do anything to the rims, but check the brake lines by the wheel, for any fluid leaking. All i did was tighten the brake lines and it solved my problem
SOLD the vr4 for an s4
13T's @ 15psi on Pump gas: 330HP/340TQ?
*DN Performance Y-Pipe*Magnacor Sparkplug Cables*NGK Irridium Spark Plugs(2 steps colder)*HKS Dual Sequential BOV
*3SX Lightweight Crank Pulley*Borla Catback*Test Pipe*ATR Downpipe*Fidanza Flywheel*RPS 6 puckClutch*Kormex Rebuilt Tranny*450cc Injectors*Apexi S-AFCII*Apexi Turbo Timer*Boost, and EGT Gauges*Stillen Brake Pads*Enkei RPO1 18X9*2 Nitto 555, 2 Pirelli PZero Nero 265/35/18*97 VR4 Brakes*GroundControl Coilovers*Drilled and slotted rotors*15psi*ProBoost MBC*FMIC, custom piping*3" GM MAS*MAFT*Dejon Tool Dual Intakes*Walbro 255 Fuel Pump*3SX Adjustable Control Arms*Fuel Rail Loop Adapter Kit*-6 Steel braided fuel lines*Aeromotive FPR*Battery Relocated in Trunk
cred05 is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 09:37 AM   #7 (permalink)
mugs's Avatar
Im 95% sure it was motor oil. It smelt like oil. My oil level was low in. There is also oil behind the wheel well moulding on the bar the is below the belt area.(Can't remember its name but looks like frame bar). There is however no visible oil on the actual belts. I'm just very scared right now.
edited for spelling.
Old 08-31-2004, 10:12 AM   #8 (permalink)
JRC
Member #140 Aug, 1998
JRC's Avatar
Drives: Caddy Escalade EXT
JRC Level 2JRC Level 2JRC Level 2JRC Level 2
Feedback Score: 2 reviews
If it's dripping and mostly in the rear half of the wheel well, it could also be a leak in the AWS Power Steering Reservoir hoses on the bottom. Check your level. It's the black thing next to your cruise control box with a wire in the cap. The fluid leaks onto the frame and travels down to the rear of the wheel well. There is a page on it in my website under repairs,,,,,, engine area.
Part of the past
1991 VR4 (Sold)
1994 Stealth (Sold)
JRC is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 10:19 AM   #9 (permalink)
Drives: 93 TT
fastmax is an unknown quantity at this point
Most likely is oil cooler --- quite a few cars that are driven in the colder climates [ road salt ] report rusted out cooler lines or fittings.
Jim Berry
Don't believe everything you think ---- fastmax
fastmax is offline   Reply With Quote Quick reply to this message
Old 08-31-2004, 05:06 PM   #10 (permalink)
is naked
Speedy's Avatar
Drives: backwards
Speedy is an unknown quantity at this point
you probably have a pinhole in the oil cooler lines up behind the fender plastic where you cant see it. check it out before you go through what i did in this thread.
Oil Cooler/ Lines burst while driving $%#@$# Damage???
251AWHP/292TQ -14psi.. knock.. aborted pull
Engine:
Rebuilt Block and Heads @ 125k -- ProBoost MBC @ 14PSI -- Spec Clutch Stage 1 -- Fidanza Flywheel -- Blue Accel Plug Wires -- Blue Silicone Vacuum Lines -- Blue Cone Air Filter -- Blue Stock Intercooler pipes -- BCP7ES Plugs @ .035 -- EGR plates -- Custom Downpipe - No Cats
Interior:
Custom White Face Gauges -- Blue Led Conversion -- Anodized Blue Pedals -- VDO Boost Gauge -- Blue Neon Foot Lights --Custom Gauge Pod -- Viper Alarm -- Custom Short Shifter - MMCD logging - Shiver's cable - Palm iiic
Exterior: Snake Eyes -- Anodized Blue Calipers -- Purple Underbody Neon -- 20% Tint -- Falken ZE512's
Audio: JVC Mp3 / CD player 200 watt -- Pioneer 10 band EQ w/ 2 way xover -- Kenwood 2 Ch 600 watt amp -- Kenwood 4 Ch 320 watt amp -- two 12" Pioneer Subs -- two 6.5" Pioneer Midbasses -- two 1" Pioneer Tweeters -- two 5.25" Pioneer Coaxials -- two 6x9" Pioneer 3 ways -- Custom Fiberglass Trunk / Sub Enclosure -- Custom Fiberglass Kickpods
Speedy is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Real Name(First & Last)
(Required/Hidden)
Mailing Address(Street)
(Required/Hidden)
City
(Required/Hidden)
State
(Required/Hidden)
Zip
(Required/Hidden)
Country
(Required/Hidden)
Date of Birth
Month Day Year
Privacy
Log-in
Random Question
