I currently have my oil pan and pump off of my 93 vr4, doing my 120k service.
I had purchased long ago an aftermatket oil pump for the car (I was cheap then, I have learned since) which I actually thought turned out to be just a front cover till about ten minutes ago. It is however a full pump (the one thar parts dinosaur sells). I also have a new oem drive and driven gear that I can use to rebuild my stocker if so desired. I'm doing this today, so I need input ASAP.
Did you measure it out? Replacing the two gears is not a complete rebuild as the other critical measurement is the gear to case clearance which has to be checked with a feeler gauge. That said a replacement is necessary to avoid oil system contamination after blowing up pistons or spinning bearings.
Related Threads
6.6M posts
61.9K members
Since 1999
