Pulled the oil pickup so I could pull the main girdle. Also see the coolant manifold on the back of the engine is seeping (not sure if that's the right term, but it's above the trans and attached to the heads. I'm guessing it has one gasket on either side and an O-ring for the coolant pipe?
Anyone have part numbers? I can't find them listed in the exploded diagrams
Thanks!
Thanks!
