Old 04-16-2008, 10:17 AM   #11 (permalink)
King3000gt's Avatar
Drives: 94' 3000gt vr-4
Trader Rating: (7)
King3000gt is an unknown quantity at this point
Default Re: Need Afc help! quick question
the link i sent you is for the neo! im 100 percent i have everythin hooked up right
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs
Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket
Need to purchase- A datalogger! leaning towards halo... got a hybrid!
King3000gt is offline   Reply With Quote
Old 04-16-2008, 10:19 AM   #12 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Updated my post. If you have everything hooked up right, in the right order, I'm baffled too. I would just say go back and make sure your Neo is configured to the correct type of vehicle.
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 04-16-2008, 12:05 PM   #13 (permalink)
King3000gt's Avatar
Trader Rating: (7)
EDIT:
Alright. Looks like brown/white does indeed go to the ECU, and black/white does come from the MAS.
Are your brown & black wires, and red & red/white wires in the right order for grounds and powers?
yes i just checked and everything it right 2 grounds 2 powers one behind the other! car idles fine but when you drive it it pops like crazy...help!
Old 04-16-2008, 07:39 PM   #14 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
I had problems few days ago:
just installed s-afc. HELP!!!!!
and it runs fine now. check it, maybe you're having same issue.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump.
Working on: Driver mod.
E85 powered VR4
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
Old 04-16-2008, 10:39 PM   #15 (permalink)
King3000gt's Avatar
Trader Rating: (7)
nah apparently my afc neo was bad, because i hooked a buddy of mines up using the same wires going to the ecu and the car ran fine
Old 05-24-2008, 09:39 PM   #16 (permalink)
Drives: 94 stealthsohcturbo
turbosohcstealth is an unknown quantity at this point
Any one know which wire is the rpm wire, on the sohc?
turbosohcstealth is offline   Reply With Quote
Old 06-03-2008, 01:35 PM   #17 (permalink)
Mitsubishistealth's Avatar
Mitsubishistealth Negative 2
hey i am having the same issuse too and i did the exact same set-up i also heard that the is a defect in the AFC NEO unit itself. Please somebody orrect me but this is why i had to upgrade to the MAFT-GEN my car is currently at
3sx they are bypassing it and tuning themft gen but what should i do the NEO hs never been used i bought it fom IPS at christmas 07
Mitsubishistealth is offline   Reply With Quote
Old 06-13-2008, 08:38 PM   #18 (permalink)
do you have a sohc, if so, what wire did you hook to to get a rpm signal?
