Old 04-15-2008, 04:11 PM   #1 (permalink)
King3000gt's Avatar
Drives: 94' 3000gt vr-4
Trader Rating: (7)
King3000gt is an unknown quantity at this point
Default Need Afc help! quick question
Does anyone know if you can intall a afc with stock fuel and just set everything to zero? i just want to install it without tuning for right now
1994 pearl yellow vr-4
Mod List- 8" k&N intake filter, HKS BOV, Blitz SBC iD III Boost Controller, Fuel Pump Hotwire, Autometer Boost Gauge, TorxMax Front Mount w/Hard Piping, EGR block-off, VAC reduction, Cross drilled and Slotted Rotors, Stillen brake pads, Stillen Downpipe, Stage 3 SPEC clutch,, MSD 8.5mm spark plug wires, and NGK spark plugs
Future Mods- Already purchased-gtpro 357 turbos, Torque Max manifolds and 02 housings, walbro 255fp, Safc neo, RC 550CC fuel Injectors, Maximal Solid Motor mounts, Maximal Transfer Case Bracket
Need to purchase- A datalogger! leaning towards halo... got a hybrid!
King3000gt is offline   Reply With Quote
Old 04-16-2008, 12:35 AM   #2 (permalink)
King3000gt's Avatar
Trader Rating: (7)
Default Re: Need Afc help! quick question
um ok well noone seems to know, so i went and installed it! i got the car to idle just fine but when you try and drive it car runs like crap... ive got everything zero'd out! not sure what to check for.
Here is another thread i started... someone please help
S-AFC help with stock fuel HELP 911
Old 04-16-2008, 04:35 AM   #3 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (60)
Yes you can do that. I have had a 0'd out SAFC in my car for years. It runs normally. If yours is not, you must have done something wrong when installing it.
2002 WJ -- 1994 VR-4 -- --Canon Rebel XTi
Old 04-16-2008, 09:39 AM   #4 (permalink)
King3000gt's Avatar
Trader Rating: (7)
ok booklet says to hook up:
Red wire: Power supply - CHECK
Green wire: rpm signal - AFC SHOWS RPM- CHECK
Red and white wire: Power supply - CHECK
Gray wire: Throttle signal - AFC SHOWS THROTTLE- CHECK
Brown wire: Grounding - CHECK
Black wire: Grounding - CHECK
Brown and white wire: Karman signal output - CAR SHOWS THERE IS A KARMAN SIGNAL NO VALUES THOUGH
Black and white wire: Karman signal input - CAR SHOWS THERE IS A KARMAN SIGNAL NO VALUES THOUGH
Orange wire: Illumination power - DID NOT HOOK UP NOT SURE WHICH WIRE TO USE
Car still runs like crap when you try and drive it normally, ive checked wires everything seems ok... i even hooked the karman signals back up stock and the car ran perfect so its got to be something with my afc just dont know
Old 04-16-2008, 09:54 AM   #5 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
Did you cut the airflow wire, put the IN into the SAFC, then take the OUT from the SAFC and connect it to the other side of the cut airflow wire?
Old 04-16-2008, 10:01 AM   #6 (permalink)
King3000gt's Avatar
Trader Rating: (7)
I cut pin number 90 thats the wire stealth316 says is my airflow... i hooked the brown/white up to the ecu side and the black/white up to the maf side
Old 04-16-2008, 10:06 AM   #7 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
It's an SAFC I or II?
Stealth316 says to use the Orange wire on the MAS side of the AF wire, and the pink wire on the ECU side. I thought the SAFC I and II had the same colored wires, except for the knock wire on the II?
Old 04-16-2008, 10:07 AM   #8 (permalink)
King3000gt's Avatar
Trader Rating: (7)
its a afc neo
Old 04-16-2008, 10:08 AM   #9 (permalink)
King3000gt's Avatar
Trader Rating: (7)
here is the instructions i was using
http://www.apexi-world.com/files/199...ng-diagram.pdf
Old 04-16-2008, 10:13 AM   #10 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (60)
EDIT:
Alright. Looks like brown/white does indeed go to the ECU, and black/white does come from the MAS.
Are your brown & black wires, and red & red/white wires in the right order for grounds and powers?
