Old 04-17-2008, 07:11 PM   #11 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Drives: 2 Pearly Whites
Joel_CA is an unknown quantity at this point
Default Re: My Vr4 Broke V Belt : (
Yes i've seen that happen several times before when i worked for Mitsubishi- and NOT only on the 3000GT. The accessory belt can get caught behind the harmonic dampener and work it's way into the timing cover where it gets in between the crank gear and Tbelt causing it to skip time. I hope this isn't your case- but losing a outer drivebelt won't prevent the engine from running (unless it's an alternator belt and the battery died).
JJ
1992 3000GT VR4 (tastefully modified) & 1996 STEALTH RT/TT #47 (restoration work in progress)
Joel_CA is offline   Reply With Quote
Old 04-17-2008, 07:14 PM   #12 (permalink)
3000 lover
mikesx4911's Avatar
Drives: 91 VR4
Trader Rating: (7)
mikesx4911 is an unknown quantity at this point
oh geez Im gonna just assume the worst now : ( my motor is fuckd Once someone tells me how 2 remove covers and etc I go do it in mean time Im gonna go cry on my gfs shoulder : ( This might be the end of my 3000gt career 4 a while : (
mikesx4911 is offline   Reply With Quote
Old 04-17-2008, 07:16 PM   #13 (permalink)
Wannabe
stealthxtreme4's Avatar
Drives: 91' Sable Black VR-4
Trader Rating: (24)
stealthxtreme4 level 6stealthxtreme4 level 6stealthxtreme4 level 6stealthxtreme4 level 6stealthxtreme4 level 6stealthxtreme4 level 6
Just go look real quick...
Jack the car up, undo the driverside wheel, and take the cover for the wheel well off, and see what damage was done to the belts.
Like I mentioned, I was thinking the powersteering belt took out the accessory,a nd you just don't have enough power because the battery is dead from running the car without being recharged.
1991 3000GT VR-4
1992 3000GT VR-4: Work in Progress
stealthxtreme4 is online now   Reply With Quote
Old 04-17-2008, 07:17 PM   #14 (permalink)
Mitsubishi Junkie
Joel_CA's Avatar
Well I was driving 2day and the car started actn all krazy as hell lol. I just went WOOT
If your car tries to tell you something- listen carefully next time and don't ignore it. Good luck!
JJ
Old 04-17-2008, 07:34 PM   #15 (permalink)
3000 lover
mikesx4911's Avatar
Drives: 91 VR4
Trader Rating: (7)
Srry that was a typo it wasnt like that I went Woot and it started actn krazy and i got out of the way of traffic quickly 2 c wth that noise was. Ok so ur sayn take the driver side tire off and than take the covers off and it will expose the belts? Oh one quick question, should I like start searching 4 a motor now? Cuz I thought it was a given if the timing belt flew off or broke or what not that the engine was fuckd.
Old 04-17-2008, 07:43 PM   #16 (permalink)
Wannabe
Trader Rating: (24)
You have no idea what is even wrong. You need to find out first. Instead of searching online for a motor you may not need, go look at the car.. even if it is 9:42 over there.
Don't assume anything.
Old 04-17-2008, 07:45 PM   #17 (permalink)
3000 lover
mikesx4911's Avatar
Drives: 91 VR4
Trader Rating: (7)
Its 2 dark outside I cant tell yes im on the same time zone as u btw, and I dont have a garage 2 pull it in my parents will bitch bitch bitch. I have 2 wait 4 daylight, and what ur sayn
Old 04-17-2008, 07:49 PM   #18 (permalink)
3000 lover
mikesx4911's Avatar
Drives: 91 VR4
Trader Rating: (7)
Yea I think Im just freakn out thats all. Tryn 2 relax but I love my car like if it was my wife lol. Um well just out of curiosity could I plug the battery up 2 the wall and try 2 start it? Just a quick and easy way of finding out
Old 04-17-2008, 08:01 PM   #19 (permalink)
Livin' the dream
chargerx3's Avatar
Drives: 92 dodge stealth TT
chargerx3 Level 1chargerx3 Level 1
yes you can, but make sure you dont have any belts loose and flying around. just poke your flashlight down there and pull out the debris...if there is any. then try starting it. if it starts making any clacking or pounding then shut it off.
...i would personally check the t-belt first, but this way works as well.
1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)...
1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT
chargerx3 is offline   Reply With Quote
Old 04-17-2008, 08:27 PM   #20 (permalink)
what would dave thomas do
Gramdollar's Avatar
Drives: 93 pearl white vr-4
Gramdollar Negative 2
k after reading your stuff something similar probably happened to you like it did to me. your crank pulley is effed and it sucked the belts into the timing belt and it might have jumped a cog or two. just get under there and look for strings coming out from behind the crank pulley... also i wouldn't try to start it
Gramdollar is offline   Reply With Quote
