Old 06-10-2008, 11:16 AM   #1 (permalink)
Jonfish490
jonfish490's Avatar
Drives: on jack stands
jonfish490 is an unknown quantity at this point
Default My engine project so far.....
Just showing some pictures of my rebuild so far. Let me know your opinions.
jonfish490 is offline   Reply With Quote
Old 06-10-2008, 11:32 AM   #2 (permalink)
'92 VR4
ras463us's Avatar
Drives: 1992 VR4
Trader Rating: (13)
ras463us Level 2ras463us Level 2ras463us Level 2
Default Re: My engine project so far.....
Looking good!
One quick item I noticed. Anywhere that something is going to be bolted to the block, remove the paint from the mating area and chase the treads.
Ricer: from the latin word Ricarius meaning to suck at everything you attempt
A person who makes unnecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
- Huge exhaust that serves no purpose but to make the car louder
- Large spoiler on the back that looks like something Boeing made for the 747
- Lots of after-market company stickers they don't have parts from, but must be cool
- Expensive rims that usually cost more than the car itself
- Body kit to make the car appear lower, usually accented with chicken wire
- Clear tail lights and corner signals
- A "performance intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
- Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some 3000gt's Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therefore not always considered rice, but it really depends on the severity of the case.
(courtesy urban dictionary)
ras463us is offline   Reply With Quote
Old 06-10-2008, 04:27 PM   #3 (permalink)
Jonfish490
jonfish490's Avatar
Going to do the oil pump tomorrow but I have one question. Where do each of the oil pump bolts go. I bought a new set because during my last rebuild I broke one and I don't want to have to go through this again....
Old 06-10-2008, 08:21 PM   #4 (permalink)
1stStealthN/A's Avatar
Drives: 94 SL, 92 VR4, 92 TT
1stStealthN/A is an unknown quantity at this point
Looks good. Are those Wisco pistons and 3SX rods? I'm doing exactly the same thing and doing the oil pump, rear seal assembly and pan this weekend.
I'm not in a hurry, too many other projects.
Did you install new oil jets? New ones cost only about $9.00 each at Mits with a discount.
How much was the balancing? My machine shop charged $285.00 and it's within 1/2 gram. Are you balancing the flywheel and clutch assembly separate from the rotating assembly?
Lay the oil pump on a flat surface and insert the bolts in the holes so they stick out above the oil pump and least 1/2 inch. Always measure the bolt hole depth too. I may be able to send a photo later in the week.
1stStealthN/A is offline   Reply With Quote
Old 06-10-2008, 09:43 PM   #5 (permalink)
havok91's Avatar
Drives: 91 RT/TT
havok91 is an unknown quantity at this point
Nice work. Did you paint the inside of the block--glyptal?
havok91 is offline   Reply With Quote
Old 06-11-2008, 11:40 AM   #6 (permalink)
Jonfish490
jonfish490's Avatar
Yep those are wisco pistons .030 over and 3sx rods. I installed new oil jets new crank new everything basically haha.
My machine work got done for free because I go to an automotive school and it just so happens I had machine shop class now so I got to do the work myself (with help of instructor) I am going to balance them separately from the rotating assembly. A picture would be helpful if you get the chance. Thanks.
Old 06-11-2008, 11:42 AM   #7 (permalink)
Jonfish490
jonfish490's Avatar
Yep painted inside with glyptal (that stuff is expensive $25 a can) I didn't want to take any chances with starving the oil pick up.
Old 06-11-2008, 01:23 PM   #8 (permalink)
I'm a dude.
Toni's Avatar
Drives: 13geed 92 rt tt
Trader Rating: (46)
Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7Toni Level 7
Originally Posted by ras463us View Post
Looking good!
+1 yup
Especially the pressure gauges. As you screw them in they will remove the paint going in and it heads right into the oiling system post filter.
My site, tons of pics/faqs(Added LED faq!)
DIY LED Kit for Sale
Speed Factor 2nd place best interior modified
'92 pearl white stealth Rt TT: Mitsu 13gs, 450cc, greddy EBC, maft gen II, Black Racing pro n1s, LC1/LM1, RPS street disc/fly,255 Walbro, high flow filter, AFPR with RobBeck adapter, Apexi el2 gauges, maximalperformance tcase bracket/adjustable arms/powdercoating, Tein S-Tech, Greddy bov, Straight exhaust, poly motor mounts, short shifter, led interior.
'06 ninja 500r
'08 vw rabbit
Toni is online now   Reply With Quote
Old 07-07-2008, 02:12 PM   #9 (permalink)
Jonfish490
jonfish490's Avatar
Got a lot further with this project have more pictures to come just waiting for the turbos and some other goodies to come.... But I have a question for now. In this picture what does the one wire left over go to? Also what is bolted up to the big red area?
Old 07-07-2008, 02:21 PM   #10 (permalink)
Quickest rebuild failure.
p2e2t2e2pete's Avatar
Drives: '92 Stealth TT
p2e2t2e2pete Level 1p2e2t2e2pete Level 1
HA! I had the exact same issue with my rebuild! That little L shaped thingey is for the top of the power steering pump! The harness mates up with the oil press. sending unit and idiot light up on the left side of the plenum correct?
p2e2t2e2pete is offline   Reply With Quote
