#1 (permalink) |
Livin' the dream
Real quick question. Is the lower intake manifold(that bolts to the block) on the base models interchangeable with the one on our TT models? they look the same in person, but i just want to make sure. mine is stripped out and im sure im losing power from it. also are all the motor mounts the same as well?
thanks
![]() 1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)... 1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TTLast edited by chargerx3 : 04-18-2008 at 08:59 AM. Reason: typo |
#2 (permalink) |
Verified Asian
Yes, and yes.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | NGK Coppers & MSD Wires | eK2 EGR Blockoffs | eK2 Fuel Line Loop | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Tein S-Tech Springs | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | VIS Hood 295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04 Collecting Dust - CM Oil Filter, Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Megan Coilovers Some Day - ABS Delete, Ducting WTB - ek2 Harness Cover (above the fuel rails) |
#4 (permalink) |
Staying in the Family
First and second gen drivers side motor mounts are different. First gens are cast steel, second gen is cast aluminum.
![]() 95 RT/TT Stock 92 VR4 Blacked out with a 98 conversion dr900's Stage 3 Heads 98 Jeep TJ 35's Locked with all the toys Cheap, Fast, Reliable.... You can only have two |
