Lean Misfires at 2700-2800 rpm - Page 82 - 3000GT/Stealth International Message Center
Old 07-26-2012, 10:01 PM   #811 (permalink)
Drives: 91 VR4
outreach is an unknown quantity at this point
Feedback Score: 0 reviews
Default Re: Lean Misfires at 2700-2800 rpm
My car just startes doing this yesterday for the second time since i owned it. I gave it a nice clean air filter and some new vac lines and this is how it treats me . First time it was a combination of having old plugs in the rear bank and new in the front and a leaking bov. This time im not so sure. It drives prlerfect then epic lean missfires for no reason.
AEM wideband, boost gauge,Y-pipe, Dieted, borla exaust,BOV,MOMO wheel, vac reduction, NGK plugs/wires, 25spline tranny/tc
To Be Installed: seattle bearing short shift, new stearing rack, solid engine mounts, MAF-T, 99 lifters, gates racing belts, 3sx tbeltcover, fidanza flywheel, ninja hotwire kit, k sports, 3sx rails+loop, AEM fuel pump, type-H RFL BOV, ninja MBC.
outreach is offline   Reply With Quote
Old 08-23-2012, 10:35 AM   #812 (permalink)
Forum user
levani041491's Avatar
Drives: 1996 3000GT&1991 vr4
levani041491 is an unknown quantity at this point
Feedback Score: 25 reviews
anybody fixed this ?
94 VR4 Single Turbo
Uploaded with ImageShack.us
levani041491 is offline   Reply With Quote
Old 08-23-2012, 01:47 PM   #813 (permalink)
luvness018's Avatar
Drives: 93 3000GT VR4
luvness018 is an unknown quantity at this point
Feedback Score: 1 reviews
i think my problem may have something to do with a clogged injector. My car used to idle fine then miss when a load was put on it, then clear up around 3k rpms. I did the vacuum reduction, new fuel filter, new plugs. it eventually got worse and started missing at idle so i was able to pull the coil wires on by one to find the bad cylinder...my plug was jet black and i couldnt smell any gas on it. Going to test some more tonight and see if the ECU is grounding the circuit out to fire the injector.
luvness018 is online now   Reply With Quote
Old 08-27-2012, 09:01 PM   #814 (permalink)
luvness018's Avatar
Default
Just to update. I found that I had a bad injector. It progressively got worse that just low rpm missing and hesitation to missing all the time. The injector ohmed out and everything but must have been clogging up our just failing. Just got a new injector on and she has never run this good!
Sent from my ADR6400L using AutoGuide.Com Free App
Old 05-20-2013, 01:32 PM   #815 (permalink)
Drives: 1991 vr4
jaysmirage is an unknown quantity at this point
Sorry to bring this back but has anyone tried dissconecting the active aero comp ?
jaysmirage is offline   Reply With Quote
Old 05-21-2013, 07:13 AM   #816 (permalink)
DoctorDex's Avatar
Drives: VR4
Feedback Score: 23 reviews
Where is that one located again? Sorry it's been awhile since I've worked on my car.
'91 VR4 - Rebuild in progress: DR900's + meth and other supporting mods.
Old 05-21-2013, 08:51 AM   #817 (permalink)
Drives: 1991 vr4
all data says Active AERO Control Unit: Rear LH Side Of Luggage Compartment
Old 05-21-2013, 08:59 AM   #818 (permalink)
Drives: 1991 vr4
THis may help
QUALITY MITSUBISHI
QUALITY MITSUB0000
Select Vehicle
New TSBs
Technician's Reference
Library Request
Conversion Calculator
1991 Mitsubishi 3000GT AWD V6-2972cc 3.0L DOHC Turbo
Vehicle » Powertrain Management » Computers and Control Systems » Crankshaft Position Sensor » Specifications
•Specifications
Advanced Ignition Timing [2]
At idle
15°BTDC
Base Ignition Timing [1]
At idle
5°BTDC
Air Flow Sensor
At 750 RPM
20 - 50 Hz
At 2,000 RPM
70 - 100 Hz
Barometric Pressure Sensor Voltage
(W/ key on and engine off)
At sea level
Approximately 4.0 volts
At 2,000 ft.
Approximately 3.75 volts
At 4,000 ft.
Approximately 3.50 volts
At 6,000 ft.
Approximately 3.25 volts
Crank Angle Sensor
Approximate Voltage at idle
1.8 - 2.5v (needle fluctuates)
EGR Temperature Sensor Resistance [3]
At 122°F (50°C)
60 - 83 Kohms
At 212°F (100°C)
11 - 14 Kohms
EGR Control Solenoid Valve Resistance [3]
At 68°F (20°C)
36 - 44 Ohms
Engine Coolant Temperature Sensor Resistance
At 68°F (20°C)
2.5 Kohms
At 176°F (80°C)
300 Ohms
Fuel Pressure Control Solenoid Valve Resistance
At 68°F (20°C)
36 - 44 Ohms
Fuel Injector Coil Resistance
At 20°C (68°F)
2 - 3 ohms
Idle Speed Control Servo Resistance
At 20°C (68°F)
28 - 33 ohms
Intake Air Temperature Sensor Resistance
At 68°F (20°C)
2.7 Kohms
At 176°F (80°C)
300 Ohms
Primary Coil Resistance
At 20°C (68°F)
0.67 - 0.81 ohms
Secondary Coil Resistance
At 20°C (68°F)
Approx 11.3 - 15.3 Kohms
TDC Sensor
2.0 - 2.5v (needle fluctuates)
Throttle Position Sensor Adjustment Voltage
At curb Idle
0.4 - 0.1 Volts
Throttle Position Sensor Resistance
Varies between
3.5 - 6.5 Kohms
Wastegate Solenoid Valve Resistance
At 68°F (20°C)
36 - 44 Ohms
[1] Refer to ADJUSTMENT PROCEDURES .
[2] Not adjustable.
[3] California Only.
Old Today, 12:55 PM   #819 (permalink)
DoctorDex's Avatar
Drives: VR4
I can't recall whether or not I disconnected the active aero or not.
With that being said, my lean misfire issued has resolved (and I still have the active aero hooked up). I'm not sure what fixed it as I changed so many variables at once, but I think it was likely related to an airflow issue possibly related to resonance in the intercooler piping system. The reason why I suspect this is because of the pressure fluctuations causing the BOV to blow off if I was to hold the rpms between 2700-3200 rpm.
