Old 05-20-2008, 09:01 PM   #791 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Default Re: Lean Misfires at 2700-2800 rpm
Not sure why they cost so much. Maybe markup?
Old 05-22-2008, 08:21 PM   #792 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
i had the exact same problem with mine. i tried to tune around it. but i had to make it pig rich to not misfire. like in the 10's when cold and low 11's when warm. i could feel it loose power during the 2500-3000 rpm band now only thing replaced is the aem. i have it in the 16-17's afr and no misfires (no load of course normal cruising). and now im gettting 19mpg with mosly city driveing(ruffed in tune). i had also replaced my ecu with a reman prior to that i replaced the ecu caps. also tested my emanage ultimate with a known good one. only thing fixed it was replacing it with a stand alone. both tunes were in speed density. i didnt even change the plugs or oil witch is overdue.
i dont know what exactly was going on but its completely gone now.
markoverclock is online now   Reply With Quote
Old 05-22-2008, 08:22 PM   #793 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
Originally Posted by DoctorDex View Post
The earliest I might be able to scrounge up enough cash for an AEM will be ~ July/August. Any chance the group buy will still be going on then?
for you ill hook ya at the time when you are ready just pm me.
Old 06-12-2008, 07:03 PM   #794 (permalink)
Trader Rating: (13)
Put some race gas in the tank to see if the knock counts I'm seeing in the suspect rpm range are phantom knock (vs. true knock). The knocking during cruise/revving in neutral was unaffected by the race gas and I continued to see 1-2 counts of knock while revving in neutral, and 1-2 sustained counts of knock (total sum ~ 10 - 12). Therefore, the knock is almost definitely phantom knock.
Anybody have any ideas with regards to the cause? Could the knock sensor be somehow "hearing" the miss? Or maybe its just my noisy valvetrain?
Old 06-12-2008, 08:14 PM   #795 (permalink)
DSM GURU
Mike1992's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (25)
Mike1992 is an unknown quantity at this point
I had alot of phantom knock in my old dsm. New set of lifters cured it
1992 Mitsubishi 3000GT VR-4 RIP 3/06
1990 Eagle Talon TSI AWD - 11.29@126 - SOLD
1991 Dodge Stealth RT/TT - Traded
1992 Eagle Talon TSI AWD - Where fast really is cheap
Mike1992 is offline   Reply With Quote
Old 06-15-2008, 07:12 PM   #796 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (19)
badass3000 Level 2badass3000 Level 2badass3000 Level 2
I am going to put my stock heads back on when I get home from the NG.
12 hrs there and 12 hrs back should give me plenty of time to run some tests to see if I notice anything else.
badass3000 is offline   Reply With Quote
Old 06-22-2008, 09:56 PM   #797 (permalink)
badass3000's Avatar
Trader Rating: (19)
alright, try to keep this short.
I discussed my problem with some 3S vets at the NG, gave some a quick ride but came up short.
then I gave a ride to Gray Haze (Grayson), for some reason the car acted fine so I couldnt show him the problem but he suggested that I throw more fuel at it.
so on the way home thats what I did.
Now I am at 14:1 most of cruzzing (20in/hg of vac),
then it dips to 13:1 around 10in/hg/-5psi
about 12:1 around 0psi,
11:1 at any boost.
and the car drives like a dream!! Damn near perfect.
the only thing is, in the situation where the car would have hesitated before,
now my knock sensor goes crazy. only in the 2500-3K zone and only with a least a little bit of load, 10in/hg or more boost.
I saw counts as high as 20 with a 13:1 AF, with 10in/hg, theres just no reason for that.
so here is what I think is going on.
I think we are dealing with only a few or one cylinders.
I think somehow its not getting enough fuel.
before the extra fuel I think a cylinder would have been way too lean to even ignite but now with the extra fuel that cylinder is now still lean, but rich enough to ignite with a hot lean combustion that results in lots of knock.
I am going to check my plugs here in a min and hopefully one looks totaly different than the others.
if not, then I might need to record individual PW or put WB sensors in each runner.
Old 06-23-2008, 10:46 AM   #798 (permalink)
badass3000's Avatar
Trader Rating: (19)
anyone see anything?
the gap on #3 in that last pic looks small. but there all the same, its just the angle.
Old 07-12-2008, 04:25 PM   #799 (permalink)
Trader Rating: (13)
Well looks like I'm going to have to put off getting the AEM. My car has much bigger problems: Catastrophic engine failure, suspect pre-ignition (Pics to follow)
Not sure whether to part it out and give up or hold on to it until I can get it back together.
Old 07-23-2008, 05:42 PM   #800 (permalink)
Trader Rating: (13)
I just got my oil analysis results back from blackstone. These results were sent away ~ 2 weeks before I destroyed my motor.
It appears the high levels of iron in my oil essentially fixed itself, therefore, this was not related to the missing. The only difference between then and now is that I recently switched to Amsoil 20W50 full synthetic racing oil. Interestingly, enough wear characteristics were improved across the board for all indicators (Amsoil 20W50 > Royal Purple 20W50 > Mobil1 10W30). The only negative in my report was that I had 2.3% fuel dilution in my oil, which effectively made the 20W50 into 10W40. I attribute this to the recent development of an extremely rich idle condition that occurs only when the car is _hot_. I have been unable to come up with an explanation of why it has been occurring and I am unsure as to whether or not it is related to the misfire problem, or if it is just another red herring. Hopefully I'll be able to come up with the cash for an AEM by spring, along with the money for a shortblock, heads and transaxle rebuild. Talk about a money pit.
