Old 11-21-2006, 05:49 PM   #72 (permalink)
That Others May Live
F27Corsair's Avatar
Drives: 92 VR4
Trader Rating: (19)
F27Corsair is an unknown quantity at this point
Default Re: Lean Misfires at 2700-2800 rpm
Badass- im not sure which wire it was, i just re-checked all of the connections. Any of the wires being off could cause a huge problem though. If i were to guess, i think either the power or ground wire were to blame.
F27Corsair is offline   Reply With Quote
Old 11-22-2006, 05:02 PM   #73 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Originally Posted by magn1t
You've probably got an ignition fault.
That causes the tach to jump and for the AFR to spike.
I'm interested in this idea. Does anybody know what else can go wrong in the stock ignition system that could cause the symptoms we've been having?
I replaced my coils, wires & plugs with the hope of fixing the problem - no go.
That leaves PTU and ECU, but both of these problems usually present differently.
Declan
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
DoctorDex is online now   Reply With Quote
Old 11-22-2006, 11:09 PM   #74 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
Steve
I dont see how that can repeatedly happen at 2700-2800rpms though
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 11-23-2006, 02:32 AM   #76 (permalink)
venik's Avatar
Drives: vr-4
venik Level 3venik Level 3venik Level 3venik Level 3
Declan
try lowering your gap, 40 thousanths is extremely high, i was getting spark blowout at .036 with almost no load, with dr650s i'd say 28-30 thousanths
venik is offline   Reply With Quote
Old 11-23-2006, 02:36 AM   #77 (permalink)
venik's Avatar
Drives: vr-4
and to explain the difference in AFR between front and rear banks, the plug thats gapped widest could be on the front bank you misfire then ecu pulls fuel and next crank is on the rear bank making it run lean, then it goes back to the front bank and its flooded with fuel making it run rich
Old 11-23-2006, 06:05 AM   #78 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (27)
John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7
If his car is like mine it doesn't lean mis-fire at higher RPM or at higher boost, so that eliminates the posibility of the ignition system not being able to jump the plug gap.
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/
For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings
http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/
John Monnin is offline   Reply With Quote
Old 11-23-2006, 10:04 AM   #79 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (18)
badass3000 Level 1badass3000 Level 1
well, my ECU is steadaly getting worst. Now im running on a max of 5 cylinders, I get false CEL that cant be read by scantools, and my Tach sometimes reads 1600rpms lower. Car is running like shit.
badass3000 is offline   Reply With Quote
Old 11-23-2006, 01:09 PM   #80 (permalink)
venik's Avatar
Drives: vr-4
i said in my post i was getting misfire with almost no load, a gap of .040 should only be used on N/A, i lowered my gap to .030 and its gone, even though you're barely putting load on the engine, it still has more pressure in the chamber than at idle. I'm not saying all of you have a gap too wide, but problems like hesitation could have alot of sources, wires, plugs, coils, or the ecu. its obvious that doctordex's plug is 10 thousanths too high, actually he might even need a gap thats lower than .026, depends on how much boost hes running at cruise and WOT, i know people who boost 20+ psi use .022 or lower
even though your not going into boost there is MORE compression at cruise than at idle, just look at your boost gauge, if you still dont believe me, check your boost gauge from 2200-3000 i bet as soon as your in the right rpm range theres a maximum compression your car will let you have before it missfires/blowsout. im not going to argue with you, theres nothing for me to gain, so if you dont believe me GL on fixing your car, because i dont know if you ever will, unless its your ecu which is a possibility.
