#761 (permalink) |
Wanted: Traction Problems
just another thing to think about... If you noticed in my video, I am no longer using the stock TB (or all the sensors/valves on it). So if my car still has this prob then I think we can rule out that stuff.
#762 (permalink) | |
Forum user
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT Mods SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html Last edited by 3000hybrid : 05-11-2008 at 12:04 PM. |
#764 (permalink) | |
I have tried to decrease my idle to stock (700 rpm), but then when I put the AC on my idle drops to 500 rpm.
'91 VR4 - Modlist: DR650R Turbos, Snow Stage 2D Alky Kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Aeromotive FPR & Filter, Hotwired Supra Pump, ek2mfg fuel loop & spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP Downpipe, Vac/EGR delete, Gutted Precats and Test pipe, Maximal Solid F/R motor mounts, 300m 18 spline output shaft, Centerforce Dual Friction Clutch, RPS Flywheel, Powerslot slotted rotors, Goodridge SS Brake lines, Hawk Pads (front), Stillen Metal Matrix Pads (rear)
#765 (permalink) | |||||
King Detail
You should ohm both your IACs per the spec in the manual. Clean out the "newer removed" one with electronic parts cleaner first and them ohm it. In fact I would clean out the one you have in as well. IE: disassemble and clean and be careful so you can reuse the internal gasket. If alcohol is getting into the IAC you may wanna reconsider the positioning of whatever you have setup on the intake. EDIT: Also, at the idle you are running there really is no point for your IAC to even be there unless you are stating your idle is that high possibly due to a vac leak.
#766 (permalink) | |
Forum user
#767 (permalink) |
cyber bully
damn, looks like my car is getting this problem
I get a lean spike when cruising at about the 2500-3000 rpm range when I roll into the throttle then it sputters some then clears out but it seems I am running leaner all over than before. Using SAFC I have increased the fuel in low throttle about 13% and this helps but it seems like I keep having to increase it more and more.I started a thread about it in the na to forced induction area because I am a TT convert. Weird and a little concerning
#768 (permalink) |
Nissans Q45, it has its oun TB positioning sensor but thats the only thing on it.
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#769 (permalink) | |
Forum user
. PM me here on on FL3S. Mann, I have watched your video a ton of times and it still sounds like something in the rear valve cover like a collapsed lifter. I think you said you've already checked them though right. ![]() Last edited by 3000hybrid : 05-12-2008 at 12:18 PM. |
#770 (permalink) | |
Forum user
| Thread Tools | |
