#661 (permalink) | |||||
King Detail
I have my own belief that ALL 1st GEN ECU's are not only trash, but also have a programming bug. I wouldn't put 1% faith in them at all. I would definitely do the idea of trying the AEM, but I know.... very expensive. Still its a small price to pay rather than spending one's ENTIRE LIFE trying to fix this car. BELIEVE ME - I KNOW HOW THAT IS! lol If no go for a try with the AEM ECU - Have you tried new O2 sensors? Have you tried TESTING your O2 sensors "out of the car"? If you don't know how I'll dig up the test method I found somewhere.
#662 (permalink) |
Wanted: Traction Problems
I hope your wrong about the 1st gen ECU's, b/c I dont want to use any other.
I love how they dont throw a CEL if you forget to buckle up. O2 sensors? what are those? I have mine unhooked, trims at 100%, b/c if I want to run lean on the interstate for beter gas milage then I can.
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#663 (permalink) | |
Resident mad scientist
I have watched the scanmaster during this transition point and spark advance does not appear to change, but the datastream may not be fully accurate....... running open loop thru this point seems to help. I just wonder if part of the transition is due to weak spark from low ignition dwell... Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!! Stock = 7300 RPM Stage 1 = 8060 RPM Stage 2 = 8200 RPM Stage 3 = 8400 RPM Stage 4 = 8800 RPM (By request only) ![]() 1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com |
#664 (permalink) |
Bob: I'll head back to the electronics place again and have the dwell tested. Another thing I'm going to do is try out your idea with the coolant resistor mod. I'm going to have them rig up a variable resistor (in line with my coolant sensor) so that way I can systematically "vary" the coolant temperature. Since this problem improves, to some degree, when the car is warm I think it'd be worthwhile to fool it into thinking it is only luke warm (120F to 165F) to see if the problem worsens. Then if the missing is unchanged, then this points to a mechanical cause.
Only problem is I don't have time to do this for at least a couple more weeks because of exams... Edit: Anybody has an MSD-DIS4? I believe these units are supposed to increase dwell in the lower rpms.
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
#665 (permalink) | |
91 Stealth TT
Have you tried just unplugging your coolant sensor? When I got my tranny swapped out a long time ago, the guy forgot to plug in my coolant sensor. The car still ran fine even though it had a CEL from it. I took it to my mechanic, and he said that when the coolant sensor is unplugged, it will feed the ECU a preset/default temperature so that the car will still run. Just a thought, dont know if it will help or not. He had one of those big OBD1 code readers, and it gave him the actual default temp it would give to the ECU during that CEL. I just can't remember the exact temp. That was almost 3 years ago.
![]() Currently a member of the Spun Bearing Club -13G's, MBC @ 15psi -ARP Head Studs, Ported Heads -Wiseco Pistons & Crower Connecting Rods -RPS Street Max Clutch & Pressure Plate -ESP Downpipe, Gutted Cats, EGR Blockoffs -3SX Polyurethane Motor Mounts -MSD 8.5mm Spark Plug Wires -Hotwired Supra fuel pump, Resistor Bypass -Dejon Dual Intakes -MAFT-Pro in Speed Density |
#667 (permalink) | |
King Detail
Are you saying you've swapped with a 3rd part ECU and that didn't fix it? I can count on 1 hand how many people have told me their 1st gen ECU was in good shape and not causing them a problem. I don't believe in "known good stock ECUs" for 1st gens (at least at this date). I have seen/heard/read of too many bad ones and in some cases people replacing them 3 times over. Regardless if its a calibration issue in the programming even if it was programmed to emissions regs it still amounts to a malfunction condition later on and shouldn't have been allowed in production no matter what the laws are. Though what does of course come to mind is that 1st gens certainly did not always behave in this faulty manner when they were new to moderate in age. Unfortunately parts of electronics as well as mechanical parts both degenerate over time and perhaps even replacement electronic parts for these boards are also deteriorated and I'm only stating this with minimal electronics experience thinking that old boards need old parts. Perhaps if one could determine what internal engine revisions may have been made from the 1st gens to 2nd gens a red flag may go off and I mean why do the 1st gens have this problem and 2nd gen's don't? If there were no internal engine changes aside from the lifter upgrades in 99 then I'd go back to what I've thought all along - electrical/board etc.. |
#668 (permalink) | |
That is a good question, the HKS DLi is another question. (I wonder whats in the HKS...) Bob |
