#631 (permalink) | |||||
King Detail
#632 (permalink) |
Sorry, what I meant was the pressure pulsing seems as though it must be related to the missing problem. Seems like too much of a coincidence that they both happen in exactly the same rpm range.
#634 (permalink) |
Wanted: Traction Problems
what do you need?
I have my OEM tranny on the bench without any plans for it. with our problem, I just found something that might be the cause of our lifter tick and might have a chance at being the real problem here. I noticed two of my lifters are soft, while the rest seem super firm. Ive only tested the few in the general area of where my ticking is coming from. in the short video below (once it uploads), I first push on a firm lifter (that seems to be normal) then I push on the other two softer ones. Im not sure, but I think if a lifter where able to move like this then the valves would not open as much, the 2mm that the lifter gives up could get magnafied by the rocker enough to keep the valve from opening.
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#636 (permalink) | |
King Detail
Dammit I was really excited about the scope results! lol - Guess we'll have to wait. |
#638 (permalink) |
Ive got a good feeling about this.
The more I think about it. The way I see it, lifters arent supposed to move (they will slowly adjust to the proper height but thats it) hense 'solid aftermarket lifters'. So If these two are broke (collapsed) then when the cam pushes on the rocker, the rocker pushes the lifter down and uses the valve as the pivot point but does not open the valve. a stuck valve will definatly cause a loss of power. I cant quite link this to 2800rpm, but maybe thats just a critical speed for the lifter. |
#639 (permalink) |
King Detail
This find stands to be the most incredible I've seen yet for this problem and because for 1 it is a "new" find (at least to me) and for 2 it is not something most people would know to look for or ever find because lets face it.... the engine being apart isn't something that happens that often.
I just hope this turns out to be "IT" and I wish that I would've been the one to find it. lol....... me or Dex. lol - but whats important is that if this is "IT" that it was found. |
#640 (permalink) |
So in your video, the two lifters (that are at the same position, ie. same cylinder) have different compressabilities? I've never seen a bad lifter, but that can't be how they are supposed to be.
If I didn't have 3 other separate projects going, I'd run out and check my lifters right now. I guess they'll have to wait until next weekend, but I think I'm going to order at least 6 lifters in advance just in case. |
