Old 02-08-2008, 05:49 PM   #601 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (14)
Default Re: Lean Misfires at 2700-2800 rpm
Originally Posted by badass3000 View Post
it says in the manual to make sure the painted (dark) part of the spring goes up.
Its pretty tough to see any paint in those pics.
Old 02-08-2008, 06:00 PM   #602 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 1StealthCRF Level 1
the dark areas at the top are what is left of the paint.
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is offline   Reply With Quote
Old 02-08-2008, 06:03 PM   #603 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
Originally Posted by TurboBob View Post
An upside down spring can only be a problem if they are asymmetrically wound. This should be visible especially if 2 springs are held next to each other and then one is flipped around.
If they are asymmetrically wound with the coils tighter at one end, the tightly wound end goes toward the head.
Anyone got pics of stock valve springs?
Bob
I have a box of about 100 of them, i'll take pics on monday.
Old 02-09-2008, 08:22 AM   #604 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4
An upside down spring can only be a problem if...
what would it do Bob?
badass3000 is offline   Reply With Quote
Old 02-15-2008, 08:25 PM   #605 (permalink)
badass3000's Avatar
Trader Rating: (20)
so, can anybody tell if the springs are different on the top?
I opened up my valve cover and even tho everything was super clean, I couldnt tell if any were upside down.
Im going to put everything back together and drive around a little this weekend. I mean its like 70* this weekend.
Old 03-04-2008, 02:21 PM   #606 (permalink)
badass3000's Avatar
Trader Rating: (20)
DoctorDex, since you and I have tried swapping in known good parts for almost everything this could be with the exception of the heads, I propose a deal.
If one of us chooses to change heads, and that fixes the problem, then the other person buys the new head gaskets.
I have my stock heads somewhere, but not much time to swap them.
If you wanted to swap your heads, I would buy your HG's.
Old 03-04-2008, 02:24 PM   #607 (permalink)
badass3000's Avatar
Trader Rating: (20)
does your rear valve cover still make noises?
mine does too, and theres no reason mine should, there super clean, freshly built, and have 99 liters
Old 03-04-2008, 02:42 PM   #608 (permalink)
Trader Rating: (14)
My rear valve cover still makes noise.
I made a video of the noise last summer with my cell phone. You can hear the valve cover noise in the first 2 seconds of this video: . The reason the sound stops is because as soon as I started moving the mike around, the phone didn't pick up the noise as well.
As far as the head gaskets are concerned, how much are head gaskets? I don't have access to any heads I could swap, so it'd probably have to be you doing the swap.
As soon as it warms up, I'm going to pull my rear valve cover off and check each lifter, each valve spring and the bearings in each of the rocker arms. I suspect I may have a flat spot in one of the rocker arm bearings (secondary to an old valve strike which resulted in the heads being rebuilt). If this fails, than I'm going to do everything I can to get my hands on an oscilloscope to test the injector waveforms during the miss...
Old 03-04-2008, 02:47 PM   #609 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
They're in my garage I have no time for car work either
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 03-05-2008, 02:16 PM   #610 (permalink)
Trader Rating: (14)
Update: Found a scope. Now all I have to do is get my car out of storage, which won't be for another couple of weeks...
