Old 12-14-2007, 09:51 PM   #581 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (21)
badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5
Default Re: Lean Misfires at 2700-2800 rpm
yeah, my cars been back together for a while, driven it around the block a few times, but the tune is soo far off its a bear to drive. I cant tell if I made any headway.
do you plan on checking your valves? Im not sure if I can check them w/o removing ALL of them. the oil on them might make the dark enamel hard to see. Its supposed to be on the top.
badass3000 is offline   Reply With Quote
Old 12-15-2007, 12:39 AM   #582 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (16)
How big of an area does the dark enamel cover? Is it just on the very top, like in the pics? Is there a way to tell by looking at the "twists"?
When I take my car out of storage in spring, I'm going to first double check that my timing belt hasn't jumped a tooth or something and I'm going to pull the valve covers off and check the clearance of the cams lobes (to make sure they are all worn equally). Then I'm going to check each rocker piece, to make sure the needle bearings inside don't have a flat spot (this tends to happen with piston-valve strikes). My motor was rebuilt ~ 20000 miles ago because of a bent valve and I don't think they changed the rocker piece, so this could be causing uneven wear and/or ticking. Lastly, if I can't find anything wrong, I'll pull each lifter out, test them and then examine the valve springs. Its too bad I have to wait until spring... my car has been in storage now for ~ 2 months and I almost feel like working on it again.
'91 VR4 - Rebuild in progress: Mods TBA.
Old 12-15-2007, 02:15 PM   #583 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7
I know its a long shot, but I really want to see a video of spark plug ingestion
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is offline   Reply With Quote
Old 12-17-2007, 10:59 PM   #584 (permalink)
I ♥ JDM Hoes Too!
10CentGT's Avatar
10CentGT is an unknown quantity at this point
Why is that many people are having this problem? I am having this problem my self too. At low RPM and higher gears, the car is misfiring and hesitating like crazy. But after like 3500 RPM, it's fine. Has any body been able to figure out this problem? If there's a boost leak, will it cause the misfiring and hesitating through out the RPM band or just at certain RPM bands? I have check every thing and at first I was thinking it might have being my emanage ultimate but I unplug it but the problem was till there. But the funny thing about it is the previous night I drove the car and it was just find. The problem just magically disappeared and now it came back as quickly as it disappeared.
10CentGT is offline   Reply With Quote
Old 12-18-2007, 11:29 AM   #585 (permalink)
Trader Rating: (16)
The missing problem that I have seems to get a bit better when the car is warm. Does that account for the difference?
Old 12-18-2007, 12:07 PM   #586 (permalink)
Drives: 1992 3000GT VR4
UCSB VR4 is an unknown quantity at this point
Just as an FYI, I'll be ditching the ARC II and switching to MAFT-PRO w/ speed density & wideband in the next few weeks.
I'll report the resulting affects on this problem.
Thanks,
Jeff
1992 RED 3000gt VR4:
Air:
DR 650s, DSM SMICs w/ 1 3/4" piping, hard pipe kit upgrade & 2 pre-turbo (no-maf) pipes w/ filters, GReddy Type-S BOV (open loop).
Fuel:
MAFT-PRO v5.03 (SD mode w/ Electronic Boost & Timing Control, GM 3 BAR MAP Sensor, GM IAT Sensor, & Innovate LC-1 wideband O2), Supra fuel pump (hotwired), 550cc PTE injectors @ 45 base psi.
Ignition:
Magnecore KV85-R100 spark plug wires, Denso iridium IK27 spark plugs gapped @ .034", Odyssey PC925 battery.
Engine:
.03" Overbore, 2nd-gen Lifters, polished heads.
Exhaust:
Gutted precats, ATR 3" downpipe, 3'' CAT, ATR 3" catback.
Drivetrain:
RPS 6-puck disk, RPS lightweight flywheel, 3sx lightweight drive pulley, polyurethane motor mounts, stillen drilled and slotted rotors, 18x9.5 5Zigen FN01RC rims, BF-Goodrich KDW-2 tires, Cusco rear strut bar.
Miscellaneous:
Corbeau seats, short throw shifter, presidential alarm system, 8 inch bazooka tube, kenwood double-din deck, 300lbs of miscellaneous weight reductions... "who's your daddy?" license plate
Future Mods:
1 Piece PST CFDS
UCSB VR4 is offline   Reply With Quote
Old 12-18-2007, 11:25 PM   #587 (permalink)
I ♥ JDM Hoes Too!
10CentGT's Avatar
No, whether warm or cold, it's still misfiring? But I took out the spark plug and I found out that 5 of the plugs were fine but one of them was really dark with a clear sign of that cylinder running really rich. Could it be that that injector on that cylinder is bad and what will it be doing?
Old 12-19-2007, 03:11 AM   #588 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT Level 1ProwlerGT Level 1
Where tha hell we at with this problem?
I've been away dealing with my life's drama drama.
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 12-19-2007, 10:30 AM   #589 (permalink)
Trader Rating: (16)
You could try swapping in a new injector...
Old 12-20-2007, 02:35 PM   #590 (permalink)
turbomaniac's Avatar
Drives: 91/99 3000gt vr4
turbomaniac is an unknown quantity at this point
I used to have that problem, for like a year in fact. I thought it was pump, injectors, or even turbos, then come to find out, it was my TPS sensor, so try that? that's what worked for me.
turbomaniac is offline   Reply With Quote
