#571 (permalink) | |||||
King Detail
Why wouldn't the cylinder fire and what would it be that would be the same for other people with the same problem at the same RPM range? How could there be no fuel dumped if the cylinder isn't firing? This would be good to watch with the exhaust OFF.... but better have some damn ear plugs. Vehicle speed sensor - My thought with that comes from the predictability of when the missing occurs. What if in that range the speed sensor is unable to distinguish (or is reporting a wrong voltage to the ECU) the vehicle speed.... wouldn't this mess things up? Its too bad moving your engine into a 2nd gen vehicle would be really hard to do..... it would iron out whether its mechanical or electrical at least.... surely a very BIG task to undertake just to find that out... would be much easier to just try your ECU in your friend's car. lol
#572 (permalink) |
I can't see it being the speed sensor as the car also misses in neutral.
The reason I'm thinking the cylinder isn't firing is because fuel isn't getting into the cylinder. This could be either because the ECU isn't telling the injector to fire, the injector just isn't firing or the valve isn't opening far enough to allow the fuel in. The reasoning behind this thinking is because the missing was "fixed" by spraying a tonne of methanol while driving in the miss range. This means that spark must be good and air flow is probably good. This is why I'd like to get my hands on an oscilloscope, so I can see what each individual injector is doing during the missing. |
#574 (permalink) |
I've done a vac. reduction, so while the car is off my evap system is closed off. When the car is running and in vacuum, vapors are pulled from the tank into the preturbo (pre-MAF) intake pipe. This shouldn't have any effect on how the car runs. Thanks for suggestion though.
#575 (permalink) | |
King Detail
#577 (permalink) |
Gixxer Fixer
Doctordex. was taking my last class for mitsu "master elite technician" status this week and was talking to some trainers and engineers from MMC about your problem. The only thing anyone came up with that you haven't covered is valve springs upside down
I know that sounds silly and far fetched but mitsubishi uses a harmonically tuned valve spring that will cause valve float around 3k rpm if inverted. the side with more twists of spring goes down. |
#578 (permalink) |
Thanks for the suggestion.
I've been wondering about some sort of valve issue, especially with the ticking noise I get from my rear valve cover. It doesn't really seem to fit 100%, but then again, nothing seems to fit 100%. I suppose maybe an intake valve could be floating/sticking resulting in only 1/2 of the required fuel getting into the cylinder??
