#541 (permalink) | |
Wanted: Traction Problems
#542 (permalink) | |
#543 (permalink) | |||||
King Detail
#544 (permalink) | |
#545 (permalink) |
I have it hooked up to the stock location (front pre-turbo pipe). Since I'm running blow through, my MAF isn't until after the turbos, so it doesn't matter how much air I pull out of the tank, it isn't going to affect my MAF readings.
#549 (permalink) |
I'm pretty sure I have the same issue, although mine is not as bad. I get rough vibrations and slight loss of power through the 2500-3000 rpm band. I am completely stock. On very hot days and warm starts (although it has to be about 20 minutes sitting), I have rough idle until hot again. I do not get any sputters when I simply rev the engine in neutral through the 2500-3000 rpm range. Vibrations seem worse under light to medium load. Driving through a neighborhood at constant speed, in 2nd gear with very light to no load in that rpm range makes the vibration happen then not happen and cycles like that about once a second. I am not as familiar as most on this site with things like datalogging and tearing my engine apart, however I did do a full tune-up using the tune-up kit from Rockville Mitsubish (includes plugs, wires, pcv, fuel filter) and this made absolutely no difference to the vibration issue in the 2500 to 3000 rpm range. I don't know if this information can help or if there is something I can check to help, but I appreciate your efforts and will be following any progress that you all make.
Lloyd - '92 Stealth R/T TT ~78k miles Firestorm Red / Black Leather - K&N filter, Halo Palm III logging, mbc running 14psi, boost gauge in glovebox, GReddy type S BOV, Red painted brake calipers, 6K HID Xenons with Hella housing, fixed Active-Exhaust & antenna, 60k maintenance, Syncromesh in transax/fer, Royal purple in Diff
