#531 (permalink) |
Resident mad scientist
I have a "BitScope" which might be good for this.
(do a google search....) B
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!! Stock = 7300 RPM Stage 1 = 8060 RPM Stage 2 = 8200 RPM Stage 3 = 8400 RPM Stage 4 = 8800 RPM (By request only) ![]() 1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com |
#532 (permalink) |
I was digging around under my dash and I found another control unit box, just wondering if anybody knows if there are any caps inside it? I am highly doubtful, this box would cause our problem, but I figured I'd throw it out there.
Part number is: MB629054 "Time & Alarm". Has anybody deleted this unit? If you don't have factory alarm is it needed? |
#534 (permalink) | ||||
King Detail
Give us a picture Dex.... either a real photo or from the CAPs program or service manual. If you look up the ECU you should see this other unit you speak of in the same diagram. If it is the unit perpendicular to the ECU (at least in my 1995 NA ATX) I believe this is the TCU. In your car it could be ECS, ABS (danger danger - don't tamper with it).... or else i dunno. Is there a separate thingy for Active Aero or is that onboard with the ECU?
#536 (permalink) |
Its under the driver side dash. It located directly up and beside the fuse block. Its more or less behind the vent that is closest to the door. Its about the size of the ECS control unit in the rear. It has the part number: MB629054 printed on the case. I looked it up in caps and all it says is: "Time & Alarm". I've disconnected it just for kicks to see if anything happens. If it doesn't do anything, then I might as well get a rid of it. Weight savings.
![]() Prowler: If you look up the part number in CAPS you should be able to find it. Once you have the part number in your list, click on the part number and then press F2, that should bring you to the part. With regards to the EVAP, I have deleted it (more or less). It is still functional, but I've done away with the solenoids and canister. Now it just dumps fumes from the tank into the intake pre-MAF while the car is in vacuum. The FP I think your probably referring to is "fuel pump". |
#538 (permalink) |
I'll have disconnecting my SAFC-2. I take it temporarily cutting the power wire should work?
With regards to the "time & alarm" control box, I found out what it is. Its the ETACS unit. It seems to control the popup headlights as well the other functions listed here: http://www.3si.org/wiki/index.php/ETACS I seriously doubt it is in any way related to our problem as I can't see any inputs to the ECU in the manual. However, with that being said, I'm going to pull the unit and revamp any old caps (if there are any). |
#539 (permalink) | |
King Detail
#540 (permalink) | |
King Detail
