Old 09-06-2007, 04:04 PM   #441 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4
Default Re: Lean Misfires at 2700-2800 rpm
Originally Posted by TurboBob View Post
So, its just lean then.......
My guess is that its such a narrow window, that its hard to tune out because the ECU re-learns the tune.
I have a few ideas. I need to get the AC/Alternator idlers changed before I can do much more testing, but I think I have a solution.
Bob
my ECU cant learn , No O2 sesors
badass3000 is online now   Reply With Quote
Old 09-06-2007, 04:13 PM   #442 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT is an unknown quantity at this point
Question Re: Lean Misfires at 2700-2800 rpm
Not to hijack the thread, but does that hurt your gas mileage much?
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 09-06-2007, 05:12 PM   #443 (permalink)
badass3000's Avatar
Trader Rating: (20)
no. it helps. ALOT! 30+MPG
Old 09-06-2007, 05:16 PM   #444 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
Trader Rating: (15)
TurboBob is an unknown quantity at this point
The Pro has lean cruise mode, so you can set it to lean out while cruising.
Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!!
Stock = 7300 RPM
Stage 1 = 8060 RPM
Stage 2 = 8200 RPM
Stage 3 = 8400 RPM
Stage 4 = 8800 RPM (By request only)
1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com
My Stealth is for sale, 65000 miles, runs perfectly. $7,500
TurboBob is offline   Reply With Quote
Old 09-06-2007, 10:00 PM   #445 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (14)
Bob, I'll get you some more logs if you need. I don't have MAP logging capability anymore (MAP sensor crapped out on me), but I can get you any other values you need. Are there any specific "logging conditions" you're looking for?
With regards to my testing, let me do another more conclusive test before we draw conclusions. I'll finally be home on Saturday (been gone since June), so I'll post my results sometime in the afternoon.
From the preliminary test, its looks like as if the ECU leans the mixture out from the 2500 - 3000 rpm range and even though you try and compensate by adding more fuel, the ecu "forgets" to inject fuel, on both banks, most often at an rpm slightly higher than 2700, but occasionally anywhere between 2500 - 3000rpm. Hence, the miss. It doesn't seem to be related to ECU learning because like badass said, it does it whether or not the O2 sensors are hooked up and it also does it at WOT. I have no idea why this is and I can't explain it.
Interested. Are you willing to share any of your ideas?
Edit: Bob, can the MAFTPro be used a drop in replacement for the MAFTranslator? Ie. I can keep the GM MAF and the MAFTPro will work as a "translator"? Does wideband tracking work if the MAFTPro is in translator mode?
Old 09-07-2007, 05:35 AM   #446 (permalink)
TurboBob's Avatar
Trader Rating: (15)
At the moment, the fix is a software tweak to the Pro. I am positive I can fix this issue, but the exact strategy is still being worked out.
The Pro can run as a translator, and works very well as such. The Pro is not an exact "drop-in" because of the wiring differences. But with a 2G MAF adapter (2G DSM = 3S) and a boomslang install harness its pretty much a plug-and-play affair.
All of the features work in Translator mode.
Bob
Old 09-07-2007, 07:51 AM   #447 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
So are you guys saying that the Pro is the problem or the Pro can be a workaround?
Dex - Have you tested your alternator at at least 2 auto stores? I say at least 2 cause I once tried it (off the car) at 5 different stores (theres a thread about it) and I got at least 3 different results.
Also, if your MAP sensor crapped out on you could that not be a cause for the problem or what am I missing there?
Old 09-07-2007, 07:53 AM   #448 (permalink)
TurboBob's Avatar
Trader Rating: (15)
The car is the problem, the Pro is the solution.
Bob
Old 09-07-2007, 08:15 AM   #449 (permalink)
King Detail
ProwlerGT's Avatar
Trader Rating: (11)
Bob
Robot Voice: AFFIRMATIVE.
Old 09-07-2007, 09:07 AM   #450 (permalink)
Trader Rating: (14)
I haven't checked my alternator yet, but I've checked my battery voltage and it always checks out (I know its not the same). I'll get it checked.
With regards to the map sensor, I was using a MAP sensor for boost logging purposes only, not for tuning, so it wouldn't affect anything.
