Old 09-04-2007, 07:59 PM   #431 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
Trader Rating: (15)
TurboBob is an unknown quantity at this point
Default Re: Lean Misfires at 2700-2800 rpm
Originally Posted by OwnGTP/WantRTTT View Post
I also switched to 560 injectors at the same time though.
I'm guessing this is a big part of it.
I have some things I'm going to try this winter on this.
Can someone summarize the RPM, TPS, and MAP readings where this happens?
B
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!!
Stock = 7300 RPM
Stage 1 = 8060 RPM
Stage 2 = 8200 RPM
Stage 3 = 8400 RPM
Stage 4 = 8800 RPM (By request only)
1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com
My Stealth is for sale, 65000 miles, runs perfectly. $7,500
TurboBob is offline   Reply With Quote
Old 09-05-2007, 03:18 AM   #432 (permalink)
Stealth Aficionado
Drives: 1995 Stealth TT
Trader Rating: (34)
OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7
I'll try to grab a log of it tonight Bob.
Tony M.
1995 Dodge Stealth R/T Turbo - 12.46@115.77
2007 Dodge Ram 1500 4x4 - 15.2 mpg
OwnGTP/WantRTTT is offline   Reply With Quote
Old 09-05-2007, 05:56 AM   #433 (permalink)
Stealth Aficionado
Trader Rating: (34)
Also Bob, I did notice that in the VE table (I’m using table #2), there is a slight shift in the table around the point where this lean spot occurs. I’ll try hooking up the logger tonight and seeing if I can tune it out using the VE table.
Old 09-05-2007, 12:12 PM   #434 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (14)
Edited my last post for clarity.
Old 09-05-2007, 01:00 PM   #435 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4badass3000 Level 4
Originally Posted by DoctorDex View Post
That has been my assumption as well. You're right, a miss will show up as a lean spot because O2 sensors measure oxygen, not fuel. What I find strange is the front and rear banks o2 sensors have identical waveforms during the miss, which makes it look like the miss is happening on both front & rear banks simulatenously.
I do have a WB and its located past the "Y" in the downpipe.
Edit: Post edited for clarity
I cant remember if NB and WB react the same to a miss?
badass3000 is offline   Reply With Quote
Old 09-05-2007, 01:15 PM   #436 (permalink)
TurboBob's Avatar
Trader Rating: (15)
they do
Old 09-05-2007, 04:57 PM   #437 (permalink)
Stealth Aficionado
Trader Rating: (34)
Bob,
Let me know what other info I can provide. I also took a log with my HHH logger so I can tell you what the ECU is reading if you'd like.
Old 09-05-2007, 06:06 PM   #438 (permalink)
Trader Rating: (14)
Conducted another test today.
Here's what I did:
1) Revved the car in neutral from 1000 rpm - 5000 rpm and made some logs. The rpm would plateau everytime it'd miss @ ~ 2700 and both front and rear O2s would read lean (as well as the WB).
2) Then I made some more logs, while revving from 1000 rpm to 5000 2-3x, on 2 separate occasions, while spraying in a mix of 80:20 methanol:H20. This caused an excessively rich mixture (beyond which my wideband can measure, probably in the 8-9 range). I was afraid of hydrolocking my motor so I didn't keep the meth-h20 on for more than 4-5 seconds.
The results: While spraying meth, there was no miss and no rpm plateau @ 2700 rpm.
I'd like to repeat this test again, using 100% meth, just so I can be sure. However, I won't be able to do this until this weekend. Nevertheless, the preliminary results point to a fueling issue, which strangely enough, does not respond to just adding more fuel with the SAFC/MAFTranslator. Whats even more strange, is its occurring on both the front and rear banks simultaneously, only in a certain rpm range.
Any ideas?
Edit: Been thinking about these results for the past couple of hours and to me, these results make no sense. Before I go jumping to conclusions, I'm going to repeat the test a few more times.
Edit2.0: Maybe its time to revisit TurboBob's idea of modifying the coolant temp sensor to dump in more fuel (and then lean it out with the SAFC).
Old 09-06-2007, 11:30 AM   #439 (permalink)
TurboBob's Avatar
Trader Rating: (15)
Bob,
PM sent
Old 09-06-2007, 11:40 AM   #440 (permalink)
TurboBob's Avatar
Trader Rating: (15)
Here's what I did:
Any ideas?
So, its just lean then.......
My guess is that its such a narrow window, that its hard to tune out because the ECU re-learns the tune.
I have a few ideas. I need to get the AC/Alternator idlers changed before I can do much more testing, but I think I have a solution.
Bob
