Old 10-11-2006, 07:49 PM   #31 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: one "badass" VR4
Trader Rating: (18)
badass3000 is an unknown quantity at this point
Default Re: Lean Misfires at 2700-2800 rpm
I unpluged my ABS, and ECS moduals = no change
swaped in a known good ecu = no change
trying a different fuel controller in the morning...
badass3000 is offline   Reply With Quote
Old 10-11-2006, 08:59 PM   #32 (permalink)
Drives: '91 VR4
Trader Rating: (13)
I'm interested to see if the different fuel controller will fix the problem.
As far as my other issue, with the spark blow out on the rear bank, I'm going to try swapping my fuel lines tomorrow, so the front bank will receive fuel after the rear bank. I'm hoping this way I can rule out a lack of fuel being the reason for my very lean rear bank O2's @ WOT.
Declan
'91 VR4 - Modlist: DR650R Turbos, Snow Stage 2D Alky Kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Aeromotive FPR & Filter, Hotwired Supra Pump, ek2mfg fuel loop & spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP Downpipe, Vac/EGR delete, Gutted Precats and Test pipe, Maximal Solid F/R motor mounts, 300m 18 spline output shaft, Centerforce Dual Friction Clutch, RPS Flywheel, Powerslot slotted rotors, Goodridge SS Brake lines, Hawk Pads (front), Stillen Metal Matrix Pads (rear)
DoctorDex is online now   Reply With Quote
Old 10-11-2006, 11:05 PM   #33 (permalink)
Getrag Wrestler
AudioPmp23's Avatar
Drives: Pearl White 93 VR-4
AudioPmp23 is an unknown quantity at this point
Hey I know this prob wont fix that specific issue but I just found out that having the stock wastegate solenoid electrically connected can still cause a vac leak even with the cap on the lower nipple. I tested it out with a hand pump vac/gauge tonight.
Hi my name's Nate and I've been addicted to boost for four years now...
AudioPmp23 is offline   Reply With Quote
Old 10-12-2006, 12:16 PM   #35 (permalink)
LeMoN1438's Avatar
Trader Rating: (30)
LeMoN1438 is an unknown quantity at this point
Originally Posted by DoctorDex
Correct me if I'm wrong, but it seems odd that coils would cause problems solely on the front bank because each coil supplies spark to both a front and rear bank cylinder. If it was a bad coil, you'd think that you'd have problems on both the front and rear. Maybe your coils were just weak in general??
It did seem odd, but thats the readings that were displayed on my datalogger. The rear bank would read .92 while the front would read ~.62, during the misfire/stutter/power loss above 4000rpms. Perhaps a faulty coil wire was the culprit, since I swapped out the entire assembly.
LeMoN1438 is offline   Reply With Quote
Old 10-12-2006, 10:07 PM   #36 (permalink)
badass3000's Avatar
Trader Rating: (18)
DoctorDex I am 100% sure your MASS is toast!!!
My LT1 was faulty also.
seems it is a common fault for GM cars too!
moral of story=GM parts suck!
Old 10-12-2006, 11:30 PM   #37 (permalink)
Drives: '91 VR4
Trader Rating: (13)
Thanks for the heads up. How did you determine your LT1 was bad? What tests can I run on mine to determine if it is the cause?
Declan
Old 10-13-2006, 12:02 AM   #38 (permalink)
badass3000's Avatar
Trader Rating: (18)
the guys at 3SX told me that it was a known fact that there can be problems with GM mass's and it is always around 3000rpm.
Old 10-13-2006, 03:03 PM   #39 (permalink)
Drives: '91 VR4
Trader Rating: (13)
I believe you, but it kind've strange because its not like the the GM MAS knows what the RPM is. Even if I add enough fuel to get it ~ stoich, I still get misfires. I've also noticed that it'll misfire (backfire) during decel when it hits 2700 rpm.
Old 10-13-2006, 03:30 PM   #40 (permalink)
keithmac is an unknown quantity at this point
Could it be resonance in the inlet manifold causing the MAS to miss-read (seems one of the only factors that`s rpm dependant?) but after saying that if you`ve increased the fueling to compensate it shouldn`t be an issue.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - Gutted MAS - K&N
Blitz SSBC - Aquamist Water Injection
keithmac is offline   Reply With Quote
