Old 08-08-2007, 06:00 PM   #371 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (21)
badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5badass3000 Level 5
Default Re: Lean Misfires at 2700-2800 rpm
If you have the money then go for it!
BTW I have a different CAS on my car now, just cant seem to get the rest of the car together to test it.
badass3000 is offline   Reply With Quote
Old 08-08-2007, 09:38 PM   #372 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (16)
Well it looks like I've committed myself to buying a DLI. It'll be a couple of weeks before it gets here. I'll let you know if it has any effect.
Apart for more upgrades? I'm curious as to what else you could possibly do to that car, its pretty sweet. If you don't mind, keep me posted re: the CAS and any other changes you've made.
'91 VR4 - Rebuild in progress: Mods TBA.
Old 08-11-2007, 01:47 AM   #373 (permalink)
Trader Rating: (16)
I know I mentioned this before, but I continue to experience many small misses and occasional large misses while cruising @ ~ 2650 rpm. The large misses are usually coupled with a relatively large manifold pressure spike, measured with an electronic boost gauge (ie. from -10cm Hg to 0.00 and then back to -10cm Hg). Not sure what to make of this. ? Mechanical issue? Valve not closing all the way prior to the initiation of combustion? Anybody know what to make of this?
Old 08-13-2007, 11:04 PM   #374 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7StealthCRF Level 7
do you still have egr
if so, just try disconnecting the solenoid connector and going for a drive
edit: oh and one more thing... if the egr connector and purge flow solenoid connector are crossed this WILL happen.. same w/ vacuum lines
edit2.0: just saw your first post. try disconecting purge solenoid if you still have it (noticed you have egr delete)
92 Stealth RT/TT Best time: 13.2 @105
StealthCRF is offline   Reply With Quote
Old 08-14-2007, 11:21 AM   #375 (permalink)
Trader Rating: (16)
I still have the EGR, which _might_ explain why I'm seeing manifold pressure fluctations (ie. unburnt fuel from the miss entering the rear manifold, igniting, and then causing the pressure spike.) I have tried disconnecting it before in the past and it didn't make a difference, hence the reason I reconnected it. This time, I'll disconnect all of the solenoids to see if it makes any difference and I'll report back.
Old 08-14-2007, 06:26 PM   #376 (permalink)
Trader Rating: (16)
Went for a drive tonight with all of the solenoids disconnected. No effect on the missing.
Left the EGR disconnected and drove for ~ 15 minutes and tried to make a manifold pressure spike/low load knock by driving in the "miss zone"; preliminary results show no pressure spike and no knock. If these results do prove to be consistently true, it would lend support to my theory that unburnt fuel is entering the rear exhaust manifold and igniting causing manifold pressure spikes +/- low load knock. I'm going to keep the EGR disconnected and I'll be driving for a number of hours tomorrow, so I will be able to better test this theory. Will report back with more info.
Old 08-14-2007, 07:20 PM   #377 (permalink)
Gixxer Fixer
StealthCRF's Avatar
Drives: on empty
awesome, hope i was able to help fix the problem
Old 08-14-2007, 08:18 PM   #378 (permalink)
mopargirl24's Avatar
Drives: '93 Stealth R/T
mopargirl24 is an unknown quantity at this point
Default Re: Misfires and/or Hesitation between 2500-2900 rpm
My car did this after overheating on the way to Colorado in 100 degree weather (the shoulder of I-70 is really the place I'd wanna be in this sort of weather...). Anyways, it fried all of my plug wires. We changed the wires and the problem was solved. Exactly what I wanted to do on my vacation. It also limited my time with my brand new nephew. Dang finicky little car. Good luck!
mopargirl24 is offline   Reply With Quote
Old 08-16-2007, 10:52 AM   #379 (permalink)
Drives: with 1g clears
Trader Rating: (20)
brattesani is an unknown quantity at this point
any updates?
Originally Posted by ilmuto View Post
because the 99 spoiler creates too much downforce at highspeeds, causing the springs to go through catastrophic failure, inducing the increase of accident risk at race speeds... or maybe not
brattesani is offline   Reply With Quote
Old 08-21-2007, 03:29 PM   #380 (permalink)
Trader Rating: (16)
Sorry, I've been away.
Here's the latest update re: the possible implications of the EGR:
It does seem as though the EGR is implicated in the manifold pressure spikes I would occasionally see while cruising @ ~ 2600 rpm. Since disconnecting the EGR, I no longer see spikes from - 10 cm Hg --> 0.00 --> -10 cm Hg.
However, I am still experiencing occasional episodes of low load sustained knock while gradually accelerating @ ~ 2600 rpm. During the most recent episode, I saw a sustained 12 counts which continued, despite 7* of timing being pulled, for a number of seconds until I was eventually forced to let off the throttle.
