#21 (permalink) |
Certified PiMp
i just had same issue, swapped ecu in and all is better now
Lamborghini Marketing VP describing Countach- "on the down side, you can't take packages, there are only two seats so no kids, only a beautiful woman. The white one, she is like a virgin. The red one is like a mature woman, the black one like an intriguing woman."
#22 (permalink) |
I had really crap part throttle miss-fire, changed the plugs and leads but that didn`t make a difference. My realtime o2 correction was pegged at 38% when it happened (max lean?). Pulled the ECU and replaced the capacitors, the difference is night and day! totally different car to drive and no missfires at all.
I don`t think you`d be able to tune though an ecu problem such as this with the SAFC because the values make no sense when the ecu goes tits up, plus the caps performance may change while driving if they`re on the way out. Seriously pull the ecu and change out the caps, I`ve read a service life of between 7 and 10 years for the caps so even the newer cars may start to suffer from this problem? |
#24 (permalink) |
I also have new caps.
I question whether or not the problem is ECU related. If it were ECU related, one would think that changing the % overclock would shift the misfiring rpm point up or down. I have tried different speeds of crystals and they have no effect on the Rpm point at which it misfires. I'm also wondering if this issue of "spark blow out" on my rear bank is related. I've never had issues, to this degree, with spark blow out. At WOT, my rear o2 voltages are dropping to 0.60V between 4600-6000rpm and then they go back to 0.91V from 6000rpm - 8200rpm. Like I said before, it doesn't feel like spark blow out and the o2 voltages aren't bouncing around. However, I have noticed that my timing will start zig zagging a bit in the 4600-6000rpm range when it is blowing out. The strangest part about it all, is that if I do back to back runs, on one run it'll bounce between 0.89-0.91V and the next it drops all the way down to 0.60V. Any ideas? If I was to try swapping in an ECU from a 93 VR4 (with a 95 engine), would this mean that he is using a 95 ECU or a 93 ECU and would I have to make any changes to my car or his ECU, so it'll work with the CAS? Thanks. Declan
'91 VR4 - Modlist: DR650R Turbos, Snow Stage 2D Alky Kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Aeromotive FPR & Filter, Hotwired Supra Pump, ek2mfg fuel loop & spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP Downpipe, Vac/EGR delete, Gutted Precats and Test pipe, Maximal Solid F/R motor mounts, 300m 18 spline output shaft, Centerforce Dual Friction Clutch, RPS Flywheel, Powerslot slotted rotors, Goodridge SS Brake lines, Hawk Pads (front), Stillen Metal Matrix Pads (rear)
#25 (permalink) | |
#26 (permalink) |
220K club
Just how lean or rich are those O2's when you think it's spark blow out? What are the AFRs exactly?
The 'bouncing timing you see, are you positive it is not just the ecu pulling timing when knock is coming on? And what the heck is "TurboBob ecu"? One of the first symptoms of an ECU (Mitsu uses) going south is the fueling...for what ever reason, a crappy ecu will often start to have problems controlling the fueling..then too lean..knock or like a bad O2 sensor run with leaded fuel, it starts to read rich so the ECU starts to lean her out terribly. Best bet_ find a stock 1st gen ECU and try that.
'92 R/T TT 236 K mileage club
AEM EMS, Twin TD-O5 MHI EVO 16G, Electronics: AEM ems, FJO dual WBO2, GaugeTech AEM ems display, custom made EL type main gauge faces, [/size] |
#27 (permalink) |
Wanted: Traction Problems
all these damn control moduals (ECU, ABS, SRS, AA, AE, ECS) are interconected. My crazy idle was caused by the ABS computer. Mabey try unhooking one at a time (or all at once) and see if it gets better.
#28 (permalink) | |
#29 (permalink) | |||
#30 (permalink) | |
OMGOMGOMGOMG
Jake - 91 VR-4
![]() Last edited by J-Ville VR-4 : 10-10-2006 at 07:57 PM. |
| Thread Tools | |
