Old 04-18-2007, 05:59 PM   #261 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Default Re: Lean Misfires at 2700-2800 rpm
I'll have to look this up, but I believe the 3 ECU "chassis ground" pins connect to different grounding points in the car??
Edit: Looked this up and here's what I found:
Pins 26 & 71 - Both ground the ECU to ground point #2, which corresponds to the point beside the wiper motor on the firewall.
Pin 13 - Is the ground for the CAS. However, I can't tell from the manual where on the car it is grounded to.
I think I'll wire up all my accessories to wires coming off of Pins 26 or 71.
Old 04-21-2007, 06:54 PM   #262 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 2badass3000 Level 2badass3000 Level 2
pins 13 and 26 are connected right off the ECU then to ground point #2 along with pin 71.
badass3000 is offline   Reply With Quote
Old 04-23-2007, 02:59 PM   #263 (permalink)
badass3000's Avatar
Trader Rating: (20)
any thing new?
did you try those other sparkplugs wires?
I still think it has something to do with my jumpy rpm that I logged.
heres what I mean...
Old 04-23-2007, 03:43 PM   #264 (permalink)
Trader Rating: (13)
Nothing new except my Supra pump died the other day. Maybe that's what was causing my car to die suddenly without explanation. Checked it with both the check connector and directly with the battery and she's dead.
As far as other things go, I found another ECU, so hopefully it'll cure my problems. Once I get it and a new fuel pump installed I'll post the results. Looking forward to getting this meth. kit installed too.
Old 04-23-2007, 03:46 PM   #265 (permalink)
badass3000's Avatar
Trader Rating: (20)
haha, did you copy any of my(Trevors) meth kit?
Ill give you some pics and details if you need them.
Old 04-23-2007, 03:58 PM   #266 (permalink)
Drives: 97 3000gt
regulator213 is an unknown quantity at this point
wow i have the same problems. except mine went away after i shut my car off. it all orignated when i sprayed mass airflow sensor cleaner on my mass airflow sensor. on the way home it started stuttering at 27-2800rpm. then it totally died. my mass airflow sensor is shot. does your car idle good? when at idle, give the mass airflow sensor a good smack with the butt of a screwdriver and see if it doesn't change the idle/kill the car. if it does then it's pry time for a new mass airflow sensor....not sure if this is any help but after 27 pages, any help is pry appreciated.
regulator213 is offline   Reply With Quote
Old 04-23-2007, 04:02 PM   #267 (permalink)
Trader Rating: (13)
A little bit yeah.
I bought the stage 2d kit with the 220psi upgrade. I was just going to go with 1 nozzle, but I figured with 2 I can customize how much meth is going in a little better, so I'm ordering the dual nozzle upgrade as we speak. As far as a tank is concerned, I found a used 3.5 L euro headlight washer tanks (with the stock fluid level indicator) to fit in the front bumper. Still waiting on it to show before I can tackle this project.
Currently researching the idea of using the AUX wire on the MAFTranslator.
Old 04-23-2007, 04:04 PM   #268 (permalink)
Trader Rating: (13)
I no longer have the stock MAF, I have a GM MAF. No idle problems, just misfires in the 2600 - 3000 rpm range, the worst part being 2700-2800 rpm. Also noticed rpm oscillate under hard acceleration (similar to badass3000's pics).
Old 04-23-2007, 04:22 PM   #269 (permalink)
Drives: 97 3000gt
yeah, my car idles perfect. it was just when it would hit 2800 it would lose most power, then gain it back at 3 with what seems to be full power. try hitting the sensor with the butt of a screwdriver or something at idle. it is worth a shot??? because it seems like we have SIMILAR problems.
Old 04-23-2007, 04:56 PM   #270 (permalink)
Trader Rating: (13)
Getting really off topic here, but maybe TurboBob can help. Bob how many volts are needed to trigger the "AUX" wire of the MAFT? I've been looking at using a relay, wired into the electronic injection solenoid of the snow kit, to trigger the AUX wire. Is 12 V from the battery too much for the AUX wire?
