Old 04-06-2007, 10:13 PM   #241 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Default Re: Lean Misfires at 2700-2800 rpm
Yeah you're right.
I've tried unplugging it and its made no difference.
Old 04-07-2007, 01:56 PM   #242 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (19)
badass3000 Level 1badass3000 Level 1
what about your RPM wire that goes to your fuel controller?
are you using the Ing wire 101 white wire or...
CAS wire 69 blue w/ stripe?
badass3000 is online now   Reply With Quote
Old 04-07-2007, 04:11 PM   #243 (permalink)
Trader Rating: (13)
For the MAFTranslator I'm not using the rpm wire. For the SAFC-2 I'm using 101.
Old 04-07-2007, 07:16 PM   #244 (permalink)
badass3000's Avatar
Trader Rating: (19)
try wire 69?
Old 04-08-2007, 12:45 PM   #245 (permalink)
OMGOMGOMGOMG
J-Ville VR-4's Avatar
Drives: 91 VR-4
Trader Rating: (13)
J-Ville VR-4 is an unknown quantity at this point
try wire 69?
Or maybe wire 68 (blue w/ red stripe), the tdc sensor (also built into the cas on 1st gens). I believe they both ultimately send out the same signal?
Jake - 91 VR-4
J-Ville VR-4 is offline   Reply With Quote
Old 04-08-2007, 02:53 PM   #246 (permalink)
Trader Rating: (13)
I tackled the issue of my TPS today.
Turns out there's nothing wrong with the TPS, as per manual. Whatever it is that supplies voltage to the TPS is bad. I measured the voltage that the TPS is seeing and all its receiving is 1.1 Volts. It should be seeing ~ 5 Volts. This is also explains why the MAP sensor wired into the EGRT input, which is using the TPS as a voltage source, doesn't work. I tried disconnecting the newly wired in MAP sensor and it had no effect.
Old 04-11-2007, 10:31 PM   #247 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
Trader Rating: (13)
TurboBob is an unknown quantity at this point
bad ECU....?
BTW, I had a thought about the stumbling.... The plugs wires run right past the CAS........
Oh, and MSD wires suck..
Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!!
Stock = 7300 RPM
Stage 1 = 8060 RPM
Stage 2 = 8200 RPM
Stage 3 = 8400 RPM
Stage 4 = 8800 RPM (By request only)
1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com
TurboBob is offline   Reply With Quote
Old 04-12-2007, 07:29 AM   #248 (permalink)
Trader Rating: (13)
Originally Posted by TurboBob
bad ECU....?
I'm 99% sure my ECU is fried so I'm actively looking for another one. However, they seem to be harder to find than I thought. I thought the plug wires running past the CAS (when I was running Accel thundersport? wires), so I switched back to my NGK resistors and it didn't make a difference.
So you don't recommend installing them?
Old 04-12-2007, 11:44 AM   #249 (permalink)
OMGOMGOMGOMG
Drives: 91 VR-4
Trader Rating: (13)
Bob
I'm curious as to your reasoning behind this statement. I'm not doubting you, I'd just like an explanation of why. I know they are really low resistance wires, I'm assuming that you are going to say that they put out a lot of EMI?
I had a set of magnecor's and swapped them out for msds awhile back. I havent noticed a difference between the two at all (I didnt expect any either). I dont have this hesitation problem that this thread is all about, btw, I'm just following along with the thread.
Old 04-13-2007, 03:23 PM   #250 (permalink)
badass3000's Avatar
Trader Rating: (19)
bad ECU....?
Bob
mine dont, I have the coils mounted on the tranny.
Bob, since my CAS is adjustable (and maxed out ) should I be able to get the same RPM signal that comes from the ignitor?
The car starts using the CAS signal but bounce revs and wont throttle up.
