#141 (permalink) |
Resident mad scientist
On my car I run with disconnected O2 sensors now and let the MAFT Pro set the AFR for me. I run 15.5:1 for lean cruise, 14.0:1 idle, etc....... But previously, I used to tune for bottomed trims for best driveability.
Bob
Need a datalogger? Check out the Scanmaster 3
PM me about ECU mods for 8000+ RPM rev limits !!!!!!!! Stock = 7300 RPM Stage 1 = 8060 RPM Stage 2 = 8200 RPM Stage 3 = 8400 RPM Stage 4 = 8800 RPM (By request only) ![]() 1991 Stealth RT/TT, Grooms Shortblock, 13G's, Translator Pro, www.maftpro.com |
#142 (permalink) |
Cheers, that`s worth knowing. I`m going to try for 90 trims and see what the drivability`s like. Had my instant o2 trim in the 40`s today while messing about, amazing how much fuel the stock ecu can pull when it wants to!.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - Gutted MAS - K&N Blitz SSBC - Aquamist Water Injection |
#144 (permalink) |
Wanted: Traction Problems
So you just richened it up at 2800rpm?
I am using a second ECU from Avpro, they told me they couldnt figure it out so they sent me another unit, and I still get the stumbles. IIRC when I was getting my car dyno tuned, the tuner told me that he could not tune the stumble out no matter how much fuel he added. Guess I will have to try it myself.
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++
![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#145 (permalink) | |
I've tried richening it up for the given rpm points (up to 30% more fuel) and it has helped to some degree (the car doesn't lurch as bad), but it still lurches. The only real fix I've been able to come up with is to cruise outside of that RPM range. ![]()
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
#146 (permalink) |
You do have an extreemly strange fault, almost between the points where the ecu wants to correct to stoich, or go into lean cruise mode (16.8:1) maybe trying to correct to stoich with fuel trims while reading the lean spot off the fuel map?.
Shame you can`t just hit the 2800 rpm range specifically, but I didn`t add anywhere near 30% fuel to correct mine.. |
#147 (permalink) |
The misfiring occurs anywhere between 2600 and 3200, just more often around the 2700-2800 range.
Does anybody know what are all of the parameters the ECU uses to determine load? Is it just airflow vs. rpm? Or are there others parameters, such as TPS, speed, coolant temp etc.? Just thinking out loud here: If this problem was ECU related, you'd assume that by changing the crystal in the ECU, ie. to a faster crystal (8200 rpm) then rpm range you'd misfire in would change, but from what I recall it had no effect. This kind've points away from ECU. Could a bad TPS with poor contacts cause these problems? I checked the adjustment of my TPS last summer and it checked out, however, I never checked to see that the changes of resistance are continuous. |
#148 (permalink) |
Im starting to think this is some sensor acting stupid also. I mean my car didnt always do this then just out of the blue started to do it. I thought it was gone when I tried a friends ECU but mabey it wasent. Think I will have to try that again. mabey start swaping all the sensors, TPS, CAS, O2, ect.
I dont use a MAS so I dont beleive this can be related to that, pretty sure I had SD working well at one point. |
#149 (permalink) |
Cooant temp is used for warmup enrichment, but when the temp gets above it`s threshold the car will run normal trims etc.
I beleive the ECU used airflow + air temp to get an air mass reading, then references against rpm and throttle position to calculate the actual engine load. What does your TPS signal look like while you`re logging the miss?. |
#150 (permalink) |
actual engine load is airflow (mass) / RPM. Fuel delivery is calculated from this since it represents the amount of air in one cylinder (properly scaled).
However, there are a bunch of airflow vs TPS style thresholds that control the fuel pump relay, decel enleanment (related to this thread), decel fuel cutoff, Power Enrichment (WOT) mode, as well as others I'm sure. The ECU cannot run 16:1 in closed loop, it is impossible with the stock O2 sensor to detect any AFR other than 14.7:1. So, to run those AFR's the ECU must open the loop. If the trims are bottomed, and the O2 trim is ~80. When the ECU opens the loop and commands 16:1, the actual AFR will be 15.5:1. Make sense? Watch the O2 trim when the ECU acts up and see if you are switching in and out of closed loop, or some other action. Also look at the TPS reading. Bob |
