Old 05-11-2008, 11:44 AM   #761 (permalink)
Wanted: Traction Problems
badass3000's Avatar
Drives: 18 Y.O. "badass" VR4
Trader Rating: (20)
badass3000 Level 2badass3000 Level 2badass3000 Level 2
Default Re: Lean Misfires at 2700-2800 rpm
just another thing to think about... If you noticed in my video, I am no longer using the stock TB (or all the sensors/valves on it). So if my car still has this prob then I think we can rule out that stuff.
badass3000 is offline   Reply With Quote
Old 05-11-2008, 11:59 AM   #762 (permalink)
Forum user
3000hybrid's Avatar
Drives: 93 VR4, 97GT FWDTT
Trader Rating: (48)
3000hybrid is an unknown quantity at this point
Originally Posted by DoctorDex View Post
Just thought I'd throw in that I partly fixed my hot start problem.
It turns out the brand spanking new ISC installed last fall had seized. I'm assuming it seized because it has been bathed in alchy for quite some time. For the time being I put my old stocker back in. Now the car starts up easily when hot, but it still runs lean for the first minute or so. Cold start ups are fine.
Interestingly enoguh, even though my ISC works, my rpms still drop when I turn on the AC? Whats up with that?
What is your ISC counts for idle.Also what's your TPS volts at at idle now? When I deleted my FIAV I had to bump my idle to about 900RPM. Before that when I would turn on my AC my idle would drop really low. Now it jumps to about 1050RPM for a sec and settles down at 900 again.
VR4-"FOR OFF ROAD USE ONLY"
97 FWDTT
Mods
SOHC to 3.1L TT swap, ATX to 5-SPEED GETRAG, TE04H DR-19T's,Wiseco Forged Pistons, Custom FMIC, RPS MAX Street clutch,Tial BOV, Walbro 255,Custom Magnaflow 3'' exhaust,ATR DP,Custom FMIC,ATR DP,Catless, 3SX crank pulley, Emanage/E01, Derale fan controller, PTE 550 inj, AEM UEGO wideband, Re-located Optima Red Top,Krank Vents, EGR Blockoffs, MMCD logger, Stillen pads, drilled rotors, EibachPro springs, 3SX intake, intake hard pipes, IPO SX AFPR, 99 lifters,99 rear garnish, Racing Hart MP3 wheels,Snow Stg 2D Meth injection/Safe inj, http://www.hesspower.com/racecar.html
3000hybrid is offline   Reply With Quote
Old 05-11-2008, 12:14 PM   #763 (permalink)
Forum user
3000hybrid's Avatar
Trader Rating: (48)
What type of TB are you using. And how do you get a throttle position reading?
Old 05-11-2008, 05:21 PM   #764 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Since I have solid mounts, idle speeds of <1000 rpm are rather annoying. Therefore, I have my idle bumped up to ~ 1000 rpm (with the AC on) and when the AC is off it sits at ~1150 rpm. My ISC count usually sits at around 0.
I have tried to decrease my idle to stock (700 rpm), but then when I put the AC on my idle drops to 500 rpm.
Old 05-11-2008, 08:02 PM   #765 (permalink)
King Detail
ProwlerGT's Avatar
Drives: 95 3000GT Base DOHC
Trader Rating: (11)
ProwlerGT is an unknown quantity at this point
Exclamation Re: Lean Misfires at 2700-2800 rpm
Drop your idle to 800 to 700. Datalog your ISC when you are turning the steering wheel while in park and also separately when you turn on the AC. You can do both at the same time if you want. If you see no counts that IAC is no good.
You should ohm both your IACs per the spec in the manual. Clean out the "newer removed" one with electronic parts cleaner first and them ohm it. In fact I would clean out the one you have in as well. IE: disassemble and clean and be careful so you can reuse the internal gasket.
If alcohol is getting into the IAC you may wanna reconsider the positioning of whatever you have setup on the intake.
EDIT: Also, at the idle you are running there really is no point for your IAC to even be there unless you are stating your idle is that high possibly due to a vac leak.
INFO LINKS FOR EVERYONE:
 ProwlerGT's Revival Thread | My Service Log | IAC | SENSORS | Hesitation Tracking List | NO3S.com
Lata,
ProwlerGT
"Those who know me, know my real name and more importantly how to say it right."
ThinkAbtIt on AIM | searcherrr on Yahoo IM | Email in profile
ProwlerGT is offline   Reply With Quote
Old 05-12-2008, 09:04 AM   #766 (permalink)
Forum user
3000hybrid's Avatar
Trader Rating: (48)
ProwlerGT is right on the money. It looks like you IAC isn't working at all. I have a spare IAC I can ship you also with the ECU. Hit me on the phone and I can get the items shipped out today for ya.
Old 05-12-2008, 09:36 AM   #767 (permalink)
cyber bully
Trader Rating: (10)
green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7green-lantern Level 7
damn, looks like my car is getting this problem I get a lean spike when cruising at about the 2500-3000 rpm range when I roll into the throttle then it sputters some then clears out but it seems I am running leaner all over than before. Using SAFC I have increased the fuel in low throttle about 13% and this helps but it seems like I keep having to increase it more and more.
I started a thread about it in the na to forced induction area because I am a TT convert.
Weird and a little concerning
green-lantern is online now   Reply With Quote
Old 05-12-2008, 11:02 AM   #768 (permalink)
badass3000's Avatar
Trader Rating: (20)
Nissans Q45, it has its oun TB positioning sensor but thats the only thing on it.
Old 05-12-2008, 12:14 PM   #769 (permalink)
Forum user
3000hybrid's Avatar
Trader Rating: (48)
Will your stocker still fit on your custom plenum? If you don't have it I can send you one of my spares for troubleshooting. They all have working sensors. I always keep the important stuff after I part cars just for these cases . PM me here on on FL3S.
Mann, I have watched your video a ton of times and it still sounds like something in the rear valve cover like a collapsed lifter. I think you said you've already checked them though right.
Old 05-12-2008, 12:20 PM   #770 (permalink)
Forum user
3000hybrid's Avatar
Trader Rating: (48)
Have you pressure tested? Sounds like a leak if it is over the entire RPM range.
