Old 11-07-2009, 02:06 PM   #21 (permalink)
jcr5186's Avatar
Drives: 91 Stealth r/t tt
Trader Rating: (13)
jcr5186 is an unknown quantity at this point
Default Re: Inconsistent high idle - very strange - Help?
It's crazy how you describe your problem is EXACTLY what my car does. Word for word.
Maybe I shouldn't waste my time/money with a new IAC.
Jon
Mods: Free Boost Mod, Vacuum Reduction, EGR Block Off, Rebuilt Stock Turbos (markoverclock), Test Pipe, Gutted Pre Cats, NGK Copper Plugs, Magnecor 8.5 Wires, Cone Intake, Manual Boost Controller (12psi), 120k Done!, MB Competition 17X9 Wheels, Kumho Ecsta ASX, Aluminum Y-Pipe, New stock clutch!
**For Sale $5,400**http://www.3si.org/forum/f10/1991-do...-400-a-461763/
Brand new Maximal Performance Adjustable Control Arms for Sale. $125 Shipped. http://www.3si.org/forum/f4/maximal-...l-arms-477812/
jcr5186 is offline   Reply With Quote
Old 11-08-2009, 07:10 AM   #22 (permalink)
Drives: 92 Twin Stealth
napkinthief is an unknown quantity at this point
Ive been having the same problem for almost 3 months.
I have vac leaks to help the idle go to 4k when i shift out of gear while braking.
2 used isc and a new isc later, still idle problem.
my ecu looks good maybe i should swap it.
napkinthief is offline   Reply With Quote
Old 11-08-2009, 02:33 PM   #23 (permalink)
Drives: 92 Stealth TT
frozenevolution is an unknown quantity at this point
Jon
You can try it and see if it cures the problem, and if it doesn't just take it back. If you find a solution, or anyone knows or has a suggestion of what to do, please let me know because this is boggling me as to what the issue could be
frozenevolution is offline   Reply With Quote
Old 11-11-2009, 11:25 PM   #24 (permalink)
Just one more thought. I noticed when it does the low rev's start, like it'll try and idle around 400/500 and almost dies until you start driving. The thing I wondered was when it's around these low numbers, if I push the throttle, the response doesn't seem to be good at all, until you start driving. Could this hint towards a bad throttle position sensor or something along those lines? Thanks.
Old 11-14-2009, 03:03 AM   #25 (permalink)
jcr5186's Avatar
Trader Rating: (13)
I'm stumped. Anyone have any test we could try?
Jon
Old 11-14-2009, 04:28 PM   #26 (permalink)
Well try this..
Next time you fire it up and its idling very low with low throttle response, floor it to 5k. When I did this, it seems to have cleared up whatever has holding it back and let it rev freely.
Im going to try a fix for this when I get my car running.
Old 11-15-2009, 02:00 AM   #27 (permalink)
Suspended
Drives: '91 3000gt VR4
Trader Rating: (20)
Schurmia is an unknown quantity at this point
check the wiring from the ecu to the ISC. I had a pin that was making a bad connection and keeping the ISC from functioning.
Schurmia is offline   Reply With Quote
Old 11-16-2009, 02:35 AM   #28 (permalink)
Originally Posted by napkinthief View Post
Well try this..
Hmm will try this next time it happens
This very well could be the case. I'll have to check the wiring this weekend. I'll report and let everyone know. Did yours occasionally idle correctly vary rarely for short moments like Jon and Mine's problem?
Old 11-16-2009, 02:48 AM   #29 (permalink)
Stuff and Junk and Things
EvanH's Avatar
Drives: NO PASSENGERS!!
Trader Rating: (7)
EvanH is an unknown quantity at this point
I had a very bad throttle searching going on not to long ago when it first started to be really cold in the mornings. Turned out I was very low on coolant for some reason. Other than I am fine with my coolant now(not running away), my idle issue disappeared. So, I will say check your coolant level, and also check your ecu coolant sensor.
Not the gauge sender and not the A/C switch.
EvanH is offline   Reply With Quote
