Hey all, I'm not sure if this is the right sub-forum for this, so I apologize if it's the wrong one.
I have a 92 Stealth TT, and on start-up the idle is usually ~1400. If its cold out it can go as high as 1900, then drop back down to ~1400 once warmed up. It's done this since I bought the car, but I never got around to trying to fix it till now.
I was going to go do all the steps the wiki has listed for high idles and such, but there is one thing that seems to be different from most cases of people with high idles, and this perhaps the key to a quick solution.
As I said, it usually is around 1400, but sometimes stays +/- 150, which seems like the typical high idle case. Occasionally, when I start the car it will idle around 800-900 and be perfect, until I start driving (even backing up out of the driveway will put it back at the 1400 mark). Then the 3rd scenario is when I start the car, it will start at 900, then go down to 500/600 and act like its going to stall, so I give it gas to keep it alive, and if left it'll drop back to the 500/600 mark; but again once I start driving, the idle changes to ~1400.
Any suggestions of what to try first? Thanks everyone
