Old 06-09-2008, 11:52 PM   #1 (permalink)
rs933000gtvr4 is an unknown quantity at this point
Question how much power?
wat do u guys think a 95 vr4 with an intake,exhaust, mbc@around 13 psi would run on a quarter mile? how much power do you guys think it should make flywheel and to the wheels?
rs933000gtvr4 is offline   Reply With Quote
Old 06-11-2008, 07:47 AM   #2 (permalink)
alottaboost's Avatar
Drives: 95 Stealth RT/TT
alottaboost is an unknown quantity at this point
Default Re: how much power?
my guess would be low 13's with about 300ish to the wheels...
alottaboost is offline   Reply With Quote
Old 06-11-2008, 04:36 PM   #3 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
mine did consistant 13.0s like that, and high to mid 12s with that and lighter wheels&carbon driveshaft at 15psi
wraith is offline   Reply With Quote
Old 06-12-2008, 11:59 PM   #4 (permalink)
so the stock rims are pretty heavy huh? what rims do you have/recomend? is there any other weight reductions that can be done to our cars?
Old 06-13-2008, 07:43 AM   #5 (permalink)
Drives: 92 VR-4
QSpectre is an unknown quantity at this point
Well wheels and a driveshaft are big ones because they are rotating mass, It's easier for the engine to turn the lighter weight things.. you could get a lightweight flywheel and that would improve thing a little.
QSpectre is offline   Reply With Quote
Old 06-13-2008, 07:47 AM   #6 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Is your clutch in good shape? If it isn't, try out the RPS Max pressure plate with an OEM clutch disc.
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
Old 06-13-2008, 07:47 AM   #7 (permalink)
dallasvr4guy's Avatar
dallasvr4guy is an unknown quantity at this point
Thumbs up Re: how much power?
Subscribe to this thread, if it takes off, you might have all the info you need soon.
3SX Performance Customer Dyno Runs-Upgrades VS Power Increases
1995 Green VR-4 - R.I.P.
Something new in the works!!
-JD Bernal
jdbernal3@hotmail.com
dallasvr4guy is offline   Reply With Quote
