Old 04-13-2008, 09:04 AM   #11 (permalink)
chask's Avatar
Drives: 3000GT-TT
chask is an unknown quantity at this point
Default Re: Hesitation @ WOT
Originally Posted by a2j View Post
so was anything done with coil packs or wires?
yes, replaced
-Coil packs
-PTU
-re-gap spark plugs
-spark plugs wires
-FPR
-ECU
I believe I found the problem, is something related with FUEL, when I just start the car (at idle) Im getting a 11.x A/F ratio with a 38psi of fuel pressure and 13.x volts to the pump. after few minutes (warms up) the fuel pressure drops to 20 or bellow and start running lean, A/F ratio readings of 18.x plus.
what could be causing the Fuel Pressure to drop?
btw Im running a Walbro 255 lhp External Fuel pump
chask is offline   Reply With Quote
Old 04-13-2008, 12:56 PM   #12 (permalink)
Drives: '91 VR4 - RIP
Trader Rating: (13)
Do you still have your FPR solenoid connected?
'91 VR4 - Modlist: DR650R turbos, Snow stage 2D alky kit, DSM SMICs, blowthrough ported LT1 MAS, Dejon Tool intakes & y-pipe, Blitz DSBC Spec R, HKS SSQV BOV, PTE 580cc injectors, Dual feed fuel system with Aeromotive FPR & filter, Hotwired Supra pump, ek2mfg plenum spacer, HKS DLI, MSD Wires, Apex'i S-AFC II, MAFTranslator, Turbobob ECU, Scanmaster III, LC-1 WBO2, ESP downpipe, Vac/EGR delete, Gutted precats and test pipe, Maximal solid mounts, 300m 18 spline output shaft, Centerforce Dual Friction clutch, RPS flywheel, GC coilover conversions with helper springs, Powerslot slotted rotors, Goodridge SS brake lines, Hawk pads (front), Stillen metal matrix pads (rear)
DoctorDex is online now   Reply With Quote
Old 04-13-2008, 05:12 PM   #13 (permalink)
chask's Avatar
Drives: 3000GT-TT
negative, I done the vac reduction.
Old 04-14-2008, 10:01 AM   #14 (permalink)
echo9's Avatar
Drives: 1993 VR4
echo9 is an unknown quantity at this point
check the voltage at the pump when it drops..
Dynamic Racing Stage II Heads, 15G TD04L Turbos, DSM SM Intercoolers, HKS SSQV BOV, K&N Air intake filter, DNP intake Y-pipe w injection port, Blitz Duel SBC Boost Controller, ACPT Carbon Fiber Drive Shaft, DENSO 550cc Injectors, Denso (Supra) fuel pump @ 43psi, Split Second Arc2 Fuel Controller w GM maf, Fuel Lab Adjustable FPR, Autometer Fuel gage on rail with loop upgrade, Magnecore 8.5mm spark plug wires, Snow Performance Methanol Injection with spray indicator led, Prosport Boost, EGT gauges
AEM UEGO Controller with Wideband O2, Cianci Custom hand made 3-pillar gauge pod, G-force steel braided brake lines, ATR downpipe, Greddy Single Shot Exhaust, NGK copper plugs, PWR aluminum radiator, RPS aluminum flywheel, RPS Stage III clutch
Polyurethane Motor Mounts, 3sx steel braided turbo oil feed lines
I love the smell of boost in the morning.... smells like.... VICTORY!!! - Apocalypse now
echo9 is offline   Reply With Quote
Old 04-14-2008, 05:45 PM   #15 (permalink)
2 Time Member of SBC
DigiiManDan3KGT's Avatar
Drives: 80Gig WesternDigital
Trader Rating: (7)
DigiiManDan3KGT is an unknown quantity at this point
Chris your front 02 voltage was .8 -.10 for the entire pull we did. Not sure why this would affect your car in closed loop mode.
Green 1995 3000GT FWD-TT 8:1 // ATX to MTX // NA to TT // Completed in 2005 // Purchased 11/12/02
White 1999 3000GT Black Dash/Tan Leather Interior // SOHC // MTX // Stock Daily Driver Purchased 7/25/07
Red.._1992 Stealth RT/TT Twin Turbo AWD // Project Car for AWD // Purchased 05/19/08
<-- Click Here Join FL3S
DigiiManDan3KGT is offline   Reply With Quote
Old 04-14-2008, 07:09 PM   #16 (permalink)
chask's Avatar
Drives: 3000GT-TT
True.
this issue only happens in open loop mode.
Old 04-15-2008, 07:35 AM   #17 (permalink)
Trader Rating: (7)
It wouldnt hurt to replace that front Narrow band 02 sensor. It'll help.
Old 04-17-2008, 08:22 PM   #18 (permalink)
chask's Avatar
Drives: 3000GT-TT
Talking Re: Hesitation @ WOT
Problem resolved!
kinked fuel line making my Fuel pressure drop to 20psi or less and of course making my car run lean!
