Old 04-06-2008, 11:23 PM   #1 (permalink)
ArmyJeff's Avatar
Drives: 1995 3000GT VR4
ArmyJeff is an unknown quantity at this point
Default Help...White Smoke, no boost, rear turbo grinding noise
ok SO HERE IS THE DEAL: as the title of the tread describes, I hav white smoke, it backfires a little at deceleration, no boost above zero, and when it gets close to zero the rear turbo makes a horid grinding noise.
This is what I did, I put MSD wires on and new plat plugs with a gap of 34. I then changed my rear motor mount with a 3SX poly and put it back together to get all what was described above. During the install of the motor mount, I removed the rear downpipe/precat, and the exhaust, as well the actuator to gain room to get to the motormount. Replaced it all the same way and put it back together. Drove the car and could not get any boost and then the grinding started. I took it apart and re-did it and no change???? Otherwise i had the intake pipes off to gain some space and then put it all back together. Motor runs fine. I get no knock according to my HHH dataloger and all sensors seem to read normal??? Any advice? Blown rear turbo seals??? HELP PLEASE!!!!
ArmyJeff is offline   Reply With Quote
Old 04-06-2008, 11:30 PM   #2 (permalink)
Livin' the dream
chargerx3's Avatar
Drives: 92 dodge stealth TT
chargerx3 Negative 1
Default Re: Help...White Smoke, no boost, rear turbo grinding noise
hmmm...white smoke makes me think of blown head gasket, or somehow your cooler lines leaking into your turbo. My vr4 had had the same issue as yours when i bought it, but i never heard it grind nor did i have white smoke. i ran rich at times, but still managed to boost.
I say pull the turbo and check it out. you can get used ones for cheep on here.
1967 Dodge Charger (440)... 1969 Dodge Charger SE (383)... 1972 Dodge Charger (400)...
1992 Dodge Stealth R/T TT (Daily Driver) 1992 Dodge Stealth R/T TT 1992 Mitsubishi 3000GT VR-4 (For Sale!)
chargerx3 is offline   Reply With Quote
Old 04-07-2008, 07:12 AM   #3 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (52)
Hannibalzero level 6Hannibalzero level 6Hannibalzero level 6Hannibalzero level 6Hannibalzero level 6Hannibalzero level 6
Are you sure its white smoke, and not black smoke from running rich? If you had a sizeable boost leak past the turbo charger, the MAS could be measuring a lot more air than is actually passing though the throttle body. This, however, would not explain the grinding.
Before doing anything else, I'd check the turbo for shaft play and to see if you can freely spin it by hand.
Old 04-07-2008, 07:27 AM   #4 (permalink)
ArmyJeff's Avatar
The car/engine does have about 120k on it, and the turbos are most likely original. The engine is running fine from what Ic an see. No knoack or anything and all injectorsare firing,etc. It runs but when I get the boost close to zero it grinds and white smoke comes out of the exhaust until I let off the gas. If it were the block or head gasket, wouldn't it smoke the whole time, not just when the turbos spool up. The grinding is clearly from the rear turbo, not the front. Haven't checked for shaft play, but I did hear that the o-ring inside the turbo goes bad and oil and coolant leak into the housing and cause smoke?!! Anyone else hear or have the same issue? Thanks for all the help. I am about to get a set of turbos from DR if the turbos are the problem.
Old 04-07-2008, 08:22 AM   #5 (permalink)
Livin' the dream
chargerx3's Avatar
Your turbos are the problem in my opinion. Mine did the same under hard acceleration,but it was a light blue= oil & fuel. check your rear turbo out before you toast it, or cause anymore damage.
Old 04-07-2008, 01:12 PM   #6 (permalink)
turbochris's Avatar
Drives: 1991 VR4
turbochris is an unknown quantity at this point
I'm pretty sure it's your turbo.Are there puddles of oil in your intercooler pipes?
A little film of oil is normal, any more means you probably have to rebuilt your turbo or get a new one,
turbochris is offline   Reply With Quote
Old 04-07-2008, 09:35 PM   #7 (permalink)
VR4Drive92's Avatar
Drives: Black VR4
VR4Drive92 is an unknown quantity at this point
is it a grind sound like a grinding wheel?
or is a grind sound that sounds like a kenne bell cobra?
if grinding wheel : possible foreign object causing failure, or thrust bearing issue causing wheels to contact their associated housings.
if kenne bell cobra : then that's more than likey journal bearing issues. But would be a bad coincidence, more than likely.
my guess. #1 Grinding wheel sound and root cause.
May the Boost be with you....
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___.
|_..._...____________======||_|_|...,]
VR4Drive92 is offline   Reply With Quote
Old 04-07-2008, 09:48 PM   #8 (permalink)
In these 10sec's or less
speeddemon11383's Avatar
Drives: 93 TT Stealth
speeddemon11383 is an unknown quantity at this point
Pull off your intake tubing and check your back turbo. That should tell you what is going on. If the turbo spins freely it's not the turbo. You should be able to reach the turbine without removing much other that the tubing. While you're at it remove the front turbo pipe too, and compare. Coming from someone who has blown 3 back 15g's it seems to me the back turbo is prone to failure before the front.
When my back turbo blew there was a bigger smoke show than a top fuel dragster doing a burn out. (Not enough time for story LOL) after that no boost, white smoke but no grinding because the exhaust turbine was in my exhaust tip, which is prob. not your case.
Parts coming! IPS Single turbo kit w/GT4202 turbo, IPS Stage 3 short block, IPS CNC'd Race heads and cams... All out drag car on the way.
93 Stealth RT/TT (Drag Car)
05 Yamaha R1 (Drag Bike)
99 Jeep Tj on 33's
90 Chevy dually. My tow truck
03 supercharged Mustang GT (girlfriends)
08 Can Am Renegade 800
speeddemon11383 is offline   Reply With Quote
Old 04-08-2008, 05:30 AM   #9 (permalink)
ArmyJeff's Avatar
Good advice from all.
I will pull piping and check on Thursday afternoon when I am free. The grinding is definitely from inside the rear turbo itself. Smoke wise, is coming directly from the rear turbo because it is not coming out of the exhaust least in the front downpipe (also need to fix this). Engine is running great to my knowledge. On the HHH logger I get no knock and all sensor and injectors look and run fine to me. Both O2 sensor even rear the same. As for the white smoke, I almost think it is the seal inside the turbos that went, and my shaft is free spinning and griding, therefore I am leaking oil or coolant into the hot exhaust side. I was looking on 3SX and their rebuild kit on their site had a good desciption of my potential problem. Check it out:
http://www.3sx.com/store/comersus_vi...dProduct=24439
I will check piping and shaft play and get back to you all. Anyone got a rear turbo without shaft play sitting around for dirt cheap (just in case)?
Old 04-08-2008, 12:16 PM   #10 (permalink)
Livin' the dream
chargerx3's Avatar
look in ebay. there is a guys who sells his rebuild kit for $90 shipped and its just the same. save yourself $60.
