Old 07-17-2008, 10:01 AM   #1 (permalink)
Forum user
Mits3kGT's Avatar
Drives: '91 VR4
Mits3kGT is an unknown quantity at this point
Default Help a Noob With This Whole Turbo Thing..
I'll make it quick, Stock Turbo's, Stock Motor with 115k (still runs strong). All BPU mods (downpipe, full 3in exhaust, text pipe, HKS SMIC's, DNP Y-Pipe, K&N Filter, Unorthodox Pully, Spec stage 3 Clutch, Walbro 255, etc)
I've got the Greddy ProfecB SpecII set at:
Gain: 35%
Set Gain: 40
Set: 45%
Peaking out anywhere between 13.8-14.3 (so roughly 14lbs')
I just went out and played around so i have no idea what the above numbers mean other then "Peak" Any suggestions?? Now i know i'm going to get flamed and yelled at, but i do not have a knock meter yet. Am i safe running 13-14lbs?? Keep in mind i dont daily drive at the settings mentioned above. Any help would be appreciated! thanks!
Mits3kGT is offline   Reply With Quote
Old 07-17-2008, 10:05 AM   #2 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: In a Man Suit
Trader Rating: (76)
lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2lawdogg Level 2
Default Re: Help a Noob With This Whole Turbo Thing..
The Pansy Patrol » Greddy Profec B Spec-II: Tuning Tips for 3/S owners
For starters your gain & setgain are WAY too high. That link will tell you all you need to know!
