Old 07-23-2008, 05:03 PM   #1 (permalink)
Drives: 91 rt/tt, 93 Bmw 325
Trader Rating: (9)
sciandra@epix is an unknown quantity at this point
Question Help with engine codes
Hello every one first off I would like to thank you for the help.
OK I have a 91 RT/TT fully built engine heads no cams with evo 16g's
I popped my logger in and found these engine codes.
13, 14, 21, 22, 25
If anybody knows what they are and can give me some insight on way I have these stored I would greatly appreciate it.
( I personally think my ecu is on the way out )
I'm also getting this weired stuttering hesitation / fuel cut feeling sometimes while driving. Check engine light will come on for a little bit, then it goes away problems go away. It can do this once to twice during a drive to 20 times a drive. Then other days nothing.????? Any help on this would be great.
Thank you
Mike
sciandra@epix is offline   Reply With Quote
Old 07-24-2008, 01:18 AM   #2 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (11)
bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5bjmsam Level 5
Default Re: Help with engine codes
CEL codes are listed in the Interpret codes section of Jeff Lucius' Reading Diagnostic Codes on the 1991-1993 Mitsubishi 3000GT/Dodge Stealth page...
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi Super AVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi Super AFC 5-knob, 450cc Black Tops, MirageCorp Logger
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 07-24-2008, 04:11 AM   #3 (permalink)
Trader Rating: (9)
Hey.
Thank you very much.
Mike
