Fuel pump re-wire/hotwire - who has done it? - 3000GT/Stealth International Message Center
Old 07-18-2010, 08:19 PM   #1 (permalink)
Twin Turbo
GTOJOE's Avatar
Drives: 1990 GTO TT
GTOJOE is an unknown quantity at this point
Feedback Score: 4 reviews
Question Fuel pump re-wire/hotwire - who has done it?
Has anyone done this? Has anyone else had the same issues Jeff had with unstable fuel pressure? I am using the stock pump while he was using the Supra pump. However at some stage I plan on fitting a Walbro pump instead.
Stealth 316 - Fuel Pump Re-Wire
Or should I be following this one instead?
RDR 3000GT/Stealth Fuel Pump Rewiring
Cheers,
Joe
1990 JDM GTO TT, oohnoo fuel loop & rail adapters, K&N FIPK, Vi-PEC plug-in V44 EMS, Iridium plugs, Turbo XS racing BOV, ARC SMIC's
"Work in progress"
GTOJOE is offline   Reply With Quote
Old 07-18-2010, 08:33 PM   #2 (permalink)
soccermania688's Avatar
Drives: Mitsubishis
soccermania688 is an unknown quantity at this point
Feedback Score: 9 reviews
Default Re: Fuel pump re-wire/hotwire - who has done it?
What i did was run a 10 awg wire from the battery to the pump. using a regular 30a automotive you use the stock fuel pump power wire as your relay trigger. you also need to do the resistor by-pass. The stock wires are very small and go a long distance so there really isn't enough power getting to the pump under stock wiring. I can't feel the transition from low speed to high speed anymore and its a lot smoother.
If you ever upgrade your pump you might over run your stock fpr and then all you would need is an aftermarket fpr. I don't think a walbro would overrun the stock fpr if its still in good conditon
1995 3000GT VR4 l New Engine/Turbos in Progress l
1992 3000GT VR4 - SOLD
soccermania688 is offline   Reply With Quote
Old 07-18-2010, 09:17 PM   #3 (permalink)
Twin Turbo
GTOJOE's Avatar
Drives: 1990 GTO TT
Have you noticed any issues with fuel pressure? Should I be also fitting an aftermarket FPR?
Old 07-18-2010, 10:03 PM   #4 (permalink)
Drives: Mitsubishis
Its not necessary with the stock pump. Fuel pressure seems fine but I don't have a gauge on it.
Old 07-18-2010, 10:15 PM   #5 (permalink)
Slow Learner
x2xtreme360's Avatar
Drives: Like a German
x2xtreme360 Level 1x2xtreme360 Level 1x2xtreme360 Level 1
Feedback Score: 17 reviews
I just did this yesterday... so it's funny to me that this thread pops up
My fuel pressure has been high for awhile. I already had the resistor bypass mod done. Here are my before and after numbers.
BEFORE:
11.23V Cold idle
10.76V Under boost
11.07V Hot idle
AFTER:
13.91V Cold idle
13.96V Under boost
13.95V Hot idle
Battery voltage: 14.09V
Obviously, the mod kept the fuel pump voltage very stable. Before it was done, voltage would DROP when it was needed most... under boost.
I ran 10AWG from the battery back to the pump. I thought about using 8AWG but went with 10 because Hosfelt didn't have 8AWG and they were VERY cheap. My install is VERY clean and I am quite satisfied with the results.
Fuel pressure is even higher now at around 50psi. Coming up next for me is an AFPR. On the plus side, my injectors flow more at 50psi... so I might even be able to go higer than 14psi of boost.
BTW, the Erik Gross method isn't the way to go... even he himself has stated high fuel pressure after doing it his way.
Vacuum reduction, Powdercoated misc, cruise relocate, Evo9 BOV, Custom catch cans, Russell fuel filter, SS braided fuel lines, High flow fuel loop, Autogage fuel gauge, Catless DP, DNP Y-pipe, Fuel pump hotwire.
FS/FT: 94 3000GT base $3k
x2xtreme360 is offline   Reply With Quote
Old 07-18-2010, 10:22 PM   #6 (permalink)
Twin Turbo
GTOJOE's Avatar
Drives: 1990 GTO TT
Thanks for the update. I will be using 8 guage wire. My main concern was the high FP. But if it doesn't cause issues I'll go ahead with it.
Cheers,
Joe
Old 07-18-2010, 10:25 PM   #7 (permalink)
Ferriolom's Avatar
Drives: 1991 Stealth R/T TT
Ferriolom is an unknown quantity at this point
Feedback Score: 3 reviews
I did the rewire in may with a 40amp relay. I have sufficent amps to the fuel pump.
Running a 255 without an FPR (I need one like Xtreme does)
kwikwire.com sells a kit for this for like $25 if you don't want to do it custom tho..
Ferriolom is offline   Reply With Quote
Old 07-18-2010, 10:26 PM   #8 (permalink)
Slow Learner
Cheers,
Joe
You will probably have higher fuel pressure... as I said, mine is at 50psi right now when it should be at ~38psi at idle.
Old 07-18-2010, 10:28 PM   #9 (permalink)
Ferriolom's Avatar
Depends. I don't think you will overrun the stock FPR with a rewired stock pump will you? With a 255 you NEED an AFPR though...
Old 07-18-2010, 10:39 PM   #10 (permalink)
Twin Turbo
GTOJOE's Avatar
Drives: 1990 GTO TT
I'm running stock boost [with free boost mod] atm and don't intend on increasing it until I have a Walbro 255. In this case I would fit an aftermarket FPR at the same time. Depending on finances I might fit the FPR sooner rather than later.
