Got around to get my pump installed and now my fuel pump doesnt turn on with the key forward....I followed the on Stealth316, but it doesn't turn the pump on when the key is forward...What could have gone bad while doing the install?
a fuse is NOT included in the hotwire kit. took me 3 days to figure out why the car wouldnt start. pop open that little black box and install a fuse. on stealth 316 theres a pic of a 30 amp so i just used a 30amp fuse too...
go fast bits...
hot wired walbro 255lph fuel pump, 550cc injectors, 3sx fuel rail loop, bigger fuel lines, K&N cone filters, Dejon 'blow through' intake pipes, GM ZO6 MAF, MAFT, Robbeck 13T turbos, FMIC with full alu. piping, MSD DIS-4 HO, 3sx radiator, HKS EVC electronic boost controller, turboxs R.F.L. BOV, maximal performance T case brace, stage 4 Competition Clutch, new output shaft / rebuilt T case, A/C delete, vacuum delete, AEM wideband O2, solid motor mounts, short throw shifter, 3sx ross pistons, 3sx rods w/ ARP bolts, new oem forged crank, clevite bearings, B&M oil cooler, AEM water meth injection.
Tuned by Ray Pampena at 3S Motorsports, 400 AWHP / 400 AWTQ @ 16psi. Currently at 24psi on pump 93.
hmmmmmmm
well i would check how you hooked the wire to the battery. (positive side)
check how it is connected to the fuel pump. double check your connections and verify the wires are in the correct place.
check your ground. i used that silverish bracket that the rear trunk struts bolt to so i know thats a good ground if your in doubt about yours.
make sure the fuel pump works. just simply pop it outta the tank and put 2 1' long wires on it and connect it directly to the battery. you should hear it start pumping.
buy a 10' long wire from your local hardware store and run it outside the car straight from the + side of the battery to the fuel pump, not connected to the relay/fuse or anything. just one end at the battery the other to the fuel pump. this will tell you if you are having an issue with your fuse/wire/connections or anything that this wire bypasses, or if its something in the pump, or that final connector from the wire to the pump. it might not tell you exactly what your issue is but it will tell you what the issue isnt, which is still helpful.
Or go to a local Harbor Freight and get a Multimeter and meter at the pump with the key on, and to the body for ground. Might aswell, since the 3s platform has a ton of electronics.
-92 Stealth RT/TT 127k (Now with 02 sensors, Keyan turbos, and a $500 longblock.) ;P
-'93 Stealth ES 5-Speed 190K+- Sold
These cars are like high-maintenance women. But unlike women, they are worth every penny!
